Search results not working unless filter is changed once
I've created a custom work-object (let's call it CUSTOBJ). In my front-end UI, I have a search box that uses the native PEGA search feature.
The problem is, when I search for a CustObj, the search doesn't return any results. I first have to change the filter "All Work Types" to any other value and then perform a search to see CustObj ojects in search results.
After that, I can move back the filter to "All Work Types" and it will still work until I log-out of the application. This behavior only happens with this new CustObj objects. Other work-objects don't see to be affected.
Has anyone encountered this problem before? I'm using v7.1.8.
Thanks for your help.
