Tech Mahindra
Last activity: 17 Jan 2017 8:52 EST
PEGA 722 Installation: Issue while loading UDF
Require your help to resolve the issue.
Below resources used for this installation
1) App server - tomcat
2) Database server - Postgres 9.3; Also tried with Postgres Plus Advance 9.5
3) JAVA version - 8
4) postgresql.conf file has also been attached
Got below error while loading UDF file:
Apply UDFs:
Apply UDFs Inner:
3) JAVA version - 8
Apply UDFs:
Apply UDFs Inner:
Load UDF:
Execute SQL In Transaction:false
[mkdir] Created dir: C:\Users\dasc\AppData\Local\Temp\1\PegaInstallTemp-23-December-2016-12.07.59\udf_temp
[copy] Copying 3 files to C:\Users\dasc\AppData\Local\Temp\1\PegaInstallTemp-23-December-2016-12.07.59\udf_temp
[echo] arg values : --config=C:\Users\dasc\AppData\Local\Temp\1\/PegaInstallTemp-23-December-2016-12.07.59/prbootstrap.properties --profile=install.postgres --dataOnly=false --run-in-transaction=false --jar-path=C:\Users\dasc\Documents\Softwares\PEGA722\scripts/../archives/udf/prreadstream.jar C:\Users\dasc\AppData\Local\Temp\1\/PegaInstallTemp-23-December-2016-12.07.59/udf_temp
[java] 2016-12-23 12:11:17,224 ( UDFManager) INFO - AutoCommit set to true. Executing with out transaction
[java] 2016-12-23 12:11:17,239 ( PostgresUDFJarLoader) INFO - Loading UDF jar on Postgres DB
[java] 2016-12-23 12:11:17,239 ( ConnectionWrapper) INFO - Attempting to load profile "install.postgres":
[java] 2016-12-23 12:11:17,239 ( ConnectionWrapper) INFO - Type: postgres
[java] 2016-12-23 12:11:17,239 ( ConnectionWrapper) INFO - Class: org.postgresql.Driver
[java] 2016-12-23 12:11:17,239 ( ConnectionWrapper) INFO - URL: jdbc:postgresql://localhost:5444/prpc
[java] 2016-12-23 12:11:17,239 ( ConnectionWrapper) INFO - User: pegauser
[java] 2016-12-23 12:11:17,239 ( ConnectionWrapper) INFO - JDBC Properties:
[java] 2016-12-23 12:11:17,551 ( ConnectionWrapper) INFO - Autocommit set to true
[java] 2016-12-23 12:11:17,567 ( PostgresUDFJarLoader) WARNING - Encountered a database problem when attempting to load jar onto PostgreSQL: ERROR: relation "sqlj.jar_repository" does not exist
[java] Position: 21
[java] *****************************************************************************************************
[java]
[java] Encountered database error attempting to load UDF library onto PostgreSQL, clean schema before running again.
[java]
[java] Exception in thread "main" org.postgresql.util.PSQLException: ERROR: relation "sqlj.jar_repository" does not exist
[java] Position: 21
[java] at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2455)
[java] at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2155)
[java] at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:288)
[java] at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:430)
[java] at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:356)
[java] at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:168)
[java] at org.postgresql.jdbc.PgCallableStatement.executeWithFlags(PgCallableStatement.java:78)
[java] at org.postgresql.jdbc.PgPreparedStatement.executeQuery(PgPreparedStatement.java:116)
[java] at com.pega.pegarules.install.udf.loaders.PostgresUDFJarLoader.isJarLoadedPostgres(PostgresUDFJarLoader.java:161)
[java] at com.pega.pegarules.install.udf.loaders.PostgresUDFJarLoader.installJarOnPostgres(PostgresUDFJarLoader.java:122)
[java] at com.pega.pegarules.install.udf.loaders.PostgresUDFJarLoader.load(PostgresUDFJarLoader.java:89)
[java] at com.pega.pegarules.install.UDFManager$AbstractUDFExecutor.loadUDFJar(UDFManager.java:348)
[java] at com.pega.pegarules.install.UDFManager$ExecuteUDFWithOutTransaction.executeInner(UDFManager.java:293)
[java] at com.pega.pegarules.install.UDFManager$AbstractUDFExecutor.execute(UDFManager.java:357)
[java] at com.pega.pegarules.install.UDFManager.process(UDFManager.java:178)
[java] at com.pega.pegarules.install.UDFManager.main(UDFManager.java:129
