Personal and Business Computers
FR
Last activity: 6 Feb 2018 11:26 EST
UDF and SQLJ SCHEMA inevitably for pega Install ?
What is User Defined Functions (UDF) ? What is SQLJ Schema ? We must inevitably install these for the Pega platform Database ?
Can we use Azure PostgreSql Database for Pega install ( without blocked by installing PL:Java for java user-defined fonctions : UDF and execute also install.sql requete to create SQLJ schema ?
I asked these questions because , I want to use Azure PostgreSql Database servers . This permit me to avoid to install virtual servers on azure cloud , and install after community postgresql database server . which saves me time and does not take care of managing database servers .
- On Pega 7.3.1 Install Tomcat PostGreSql guide , it's written :
" Installing PL/Java for Java user-defined functions :
The Pega Platform requires Java user-defined functions (UDFs). To work with PostgreSQL, UDFs
require the PL/Java add-on for PostgreSQL and a new dedicated schema. The new schema, called
SQLJ, is defined for the Pega Platform database.
For PostgreSQL 9.3 and later, the PL/Java module is included in the Pega Platform resource kit.
Before you install the Pega Platform, install the version of PL/JAVA included in your resource kit. If
you do not install and configure PL/Java before you attempt to install the Pega Platform, the Pega
Platform installation fails. Follow the instructions for your platform."
- On this link Deploying Pega Platform on Microsoft Azure:
https://docs.pega.com/client-managed-cloud-deployments-prior-pega-platform-82/deploying-pega-platform-ms-azure , it's mentionned :
" Note : The Azure SQL Database service does not allow installation of user-defined functions (UDFs). Therefore, before you install Pega Platform, set bypass.udf.generation=true in the setupDatabase.properties file. For more information, see your Pega Platform Installation Guide. "
- On this link also Deploying Pega Platform on Amazon Web Services : https://docs.pega.com/client-managed-cloud-deployments-prior-pega-platform-82/deploying-pega-platform-aws :
" The Amazon RDS service does not allow installation of user-defined functions (UDFs). Therefore, before you install Pega Platform, set bypass.udf.generation=true in the setupDatabase.properties file. For more information, see your Pega Platform Installation Guide. "
Thank you for yor help
