Buttons are displaying partially in firefox browser
Can you please provide screenshot, Pega Version
Hi Siva
As Shashi has requested, please provide screen shot of issue, Pega version, browser version.
Also clarify, if it is a question of just display or functionality. Does the button click work even though it is partially visible? Does the button show and work correctly on another browser say, Chrome or IE?
See if this post is applicable to you.
https://community.pega.com/support/support-articles/button-control-does-not-work-firefox-browser
Bhuvana.
Hi ,
Pega Version is 7.1.8 and the issue is just display . functionality is fine.
screenshot is there in the descrition , button display is half cut
thanks & regards,
siva chaganti
Siva,
Can you confirm you're using the new Pega 7 version of the button control?
Your screenshot is not visible. Can you upload it via Add a new File instead of pasting in RTE control.
Hi ,
Attached the screenshot . and we are using latest version of Button control which is in 07-10-17.
Siva chaganti
Hi Siva
Can you confirm if this works correctly for you in Chome and IE?
Can you check your skin to see if you have applied any custom styles to buttons?
What is your zoom percentage?
Are you facing an issue only with buttons in firefox or other controls as well?
Can you check in the UI gallery what the buttons look like in firefox for you?
Hi siva
From the screen shot it looks like you are in a screen flow. Is the issue with a button only for the screen flow buttons ? (OR) for all flow action buttons ?
If noticed only for screen flow buttons , are you using your own screen flow harness
It is for all flow action buttons and it is working fine in IE and Chrome .
Can you tryi logging in as Administrator@pega.com, and run one of the Out of the Box flow PegaSample-CustomerRequest.NewWork (O)R PegaSample-Task.BaiscProcess in Firefox and let us know if the issue shows up there as well ?
Also, UI gallery samples, dont they also not show up correctly ?
