Murex
LB
Last activity: 4 Nov 2016 0:31 EDT
'Delete Item' behavior in Repeat Grid
I have a Repeat Grid reading from a Report Definition.
The user has the option to remove/delete a row: On click of the delete icon, run the action 'Delete item'.
It works properly for all rows except for the last row in the grid. In that case, the row is not deleted.
Note that the issue is not reproduced when using a Data Page that is Editable.
Any ideas of why the last row in the grid is not being deleted properly?
Thank you in advance,
Mariane
***Updated by Moderator: Marissa to update topic categories***
Murex
LB
For now I am using a data page instead of a report definition, this solves the problem !
Murex
LB
Any ideas about the above ?
Levis
I am able to delete any row from the grid. Did you have the same configuration as below?
Murex
LB
Hello
Thank you for your reply !
I have the same configuration.
I am able to delete any row except the last one. Are you able to delete the last row successfully (when grid reads from report definition)?
Mariane
Salame
I'm facing same issue. Any help is appreciated!
thanks in advance,
Rosy
Levis
Yes... I have report definition as the source... and i am able to delete the last row. I tried it in Pega 7.1.9 and 7.2.
What is the Pega version that you are using?
BlueRose Technologies
SE
Hi MarianeA,
Can you please create an SR for your issue. Or, please provide the below information.
1) what is the pega version which you are using.
2) which pega Framework you have installed.
3) configuration settings of the repeat grid.
4) Does the section is getting refreshed and ListEditorProcess is getting called.
5) If yes, what is the behaviour of 13 th step in that activity.
Thanks and Regards,
Prudhvi
Murex
LB
Hello Prudhvi,
Thank you for your reply. It is much appreciated.
Below are the information requested:
1) Pega version 7.2
2) CS Framework
3) Configuration settings for the repeat grid (General + Opeartions + Presentation + Actions):
Hello Prudhvi,
1) Pega version 7.2
2) CS Framework
4) ListEditorProcess is not being called
Please let me know if it requires a Support Request.
Thank you very much Prudhvi,
Mariane
SE
Hi MaraineA,
Thanks for providing the attachments. I have replicated your scenario and it is not replicable in PRPC 7.2 platform. I suspect that this is occuring due to Framework rules. So, can you please create a support request for this.
Thanks and Regards,
Prudhvi
Murex
LB
Hello Prudhvi,
Thank you very much, I will go ahead an create an SR.
Thanks and Regards,
Mariane
Hi Mariane,
Please let us know the SR number once you create it. We will tag it here for effective tracking!
Lochan | Community Moderator | Pegasystems Inc.
Murex
LB
Hello Lochan,
I will let you know the SR number once created. Thank you very much :)
Mariane
Murex
LB
