Tata Consultancy Services
Delete item in Repeating grid not working
I am trying to delete rows from repeating grid using the Delete Item button in the grid header. but it is not working. can someone please help me on this?
Hi Shalini,
Assuming that you are using 7.1.6.
Please check the following:
Please check for the following in the Grid properties
Operations Tab-> Row Editing Must be Inline -> Inline EditMode -> Rows Always Editable
Actions Tab -> Keep the eveny and Event action as default.
Dmytro Malkov Megna N
Wipro Ltd
Assuming the user is using Pega7, following are the settings that the user has to do in the GRID to make the buttons editable.
Operations Tab -> Row Editing -> must be Inline
Inline Edit Mode -> must be Rows Always Editable
Megna N venu kampalapalli
Verizon
Thanks Kiran, this worked
Dear Kiran and SATAS,
Thanks for the detail. This works.!
Agora Group Inc
We are in 7.1.7 and seeing the same issue. We tried above mentioned configuration but no luck.
Am i missing anything else other than above updates ?
C
United health group
HI Chaitanya,
I am also using 7.1.7 and facing same isssue can you please tell me is your isue resolved?
are you seeing any lock lost issues while deleting the row?
Pega
Hi Chait & Pavani,
Whether you configured action set as Delete item on the link/button?
Infosys Ltd
DE
I am also facing the same issue.
The 'Delete item' is configured in the action set.
After delete item, the 'refresh - this section' is also set.
The row editing is 'inline' edit mode is set to 'rows always editable'.
Thanks.
Supriya
State of Maine
Hi guys,
I am on Pega 7.1.9 and this configuration works ., Removes from my pagelist property., Working as expected.
Thanks,Vamsi.
