  srcLogic
Last activity: 21 Nov 2016 2:32 EST
Link doesn't start file download if other link has already been clicked
I have a template documents page that has a link for each template document. On each link, I configured the section to refresh + activity DownloadBinaryFile to run on click, as shown in the first screenshot. All links work if another link has not been touched. But once one link is clicked, clicking another link does not lead to any file download. I checked the tracer and it is still executing the activity properly on the 2nd click but nothing is downloaded. How can I make all links work always?
Isabella
***Updated by moderator: Lochan to add SR details***
Hello!
Upon reviewing the corresponding SR, we see that it has been resolved. SA-30316 was created as a result of the investigation. Please reference that if you have the same question.
Lochan  |  Community Moderator  |  Pegasystems Inc.
  srcLogic
Any help would be appreciated!
  Shell
Hi Isabella,
Out of the box, I dont find the activity named DownloadBinaryFile.Could you please provide the screenshots of the activity configuration.
Chinmai Sravanthi.
  srcLogic
Hello Chinmai,
The activity is pyDownloadBinaryFile, as shown in the screenshot attached. Let me know if that helps.
  Cognizant Technologies
Can you verify, is their any js file is included in Harness. After an event is triggered, it is disabling / not allowing to trigger any more events. can you add a test button in the same section with sample pop up and see is that working, this is to insure no issues with event trigger.
  srcLogic
Hello Pavan,
I added a button that triggers a web browser to pop up and that button works after clicking a link, so other events can be triggered.
  srcLogic
This is still a problem for me, any help is appreciated!
Hi Isabella,
I was able to see the same issue at my end.
Could you please raise an SR for this?
Gisela
  Infosys
BE
Hi Isbella,
On click of link, while downloading can you call pyAttachmentFeedDescription control as shown in the attached screenshot and give a try? Please dont mention any onclick activitys. It works.
  Jananee Kalaichelvan
Hi Isabella,
Please let us know the SR number once you create it. We will then tag it to your post for effective troubleshooting.
  COFORGE DPA UK LTD
I have seen similar issues related to links in 6.1 version. There may be problematic data on clipborad. I have solved this issue by writing Java script and added script at harness level. I hope Pega support team can resolve this problem.
Gaurav
  srcLogic
SR is SR-B1487
I am not sure why you are using refresh section to call the activity which leads to download the binary file. I think we should use open url in window to call the activity. Can you give it a try and let us know the results.
Note: Please check the may start option in the activity security option to allow calling the activity from the client side.
-Saikat
Hello!
