BNYMellon Technology
Last activity: 13 Dec 2016 10:39 EST
OOB AttachAFile in section pyCaseAttachments Not attaching File
The Add option in Section pyCaseAttachments is not attaching files but works for URL. When traced its because Param.hiddenFilePath is spaces.
pxRequestor.pyFileUpload : file://web:/StaticContent/global/ServiceExport/nullfile://web:/StaticContent/global/ServiceExport/test - 1.txt
This is happening in our application. In Other applications its working fine. We compared the tracer outputs of both and the difference is Param.hiddenFilePath. Any help on why the Param.hiddenFilePath is spaces and ultimately resolving this issue???
Attaching all req screenshots
Arvind B
***Updated by Moderator: Lochan. Removed user added Ask the Expert tag. Apologies for confusion, shouldn't have been an end-user option; updated Category***
***19/10/16: Updated by moderator: Lochan to add SR details***
Hello!
Upon reviewing the corresponding SR, we see that it has been resolved. SA-30534 was created as a result of the investigation. Please reference that if you have the same question.
Lochan | Community Moderator | Pegasystems Inc.
Hi Arvind,
Thank you for posting the question.
Could you specify the version of Pega that you are using?
Thank you.
We are using 7.1.5
Hi Arvind,
What is the behaviour observed when you drag-drop the file?
Hi Evita
Drag-Drop is working fine.
I tried to watch "pxRequestor.pyFileUpload" .. below is set as soon as OK is clicked after selecting the file through browse ...
OldValue undefined
CurrentValue file://web:/StaticContent/global/ServiceExport/null file://web:/StaticContent/global/ServiceExport/test - 1.txt
Hi Arvind,
Kindly raise an SR for the same as it requires investigation.
Thank you.
Navy Federal Credit Union
Arvind,
If you do end up opening an SR please reply here with your SR number so we may track within your post as well as attach this troubleshooting with the SR to assist the Engineer who will work it.
Thanks!
Marissa | Community Moderator | Pegasystems Inc.
Hi All
SR-B633 Raised for this issue. Will keep the progress posted.
Thanks Arvind,
I have tagged the post above with the SR details. Good work on mentioning the URL of this post in the SR, that helps!
Hello!
