![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1690008000/6e91ea19-04b7-48d3-92a5-81a4c856cb82.jpg?itok=XCQHtc1j)
AreteansTech
Last activity: 20 Nov 2016 16:57 EST
Create work cases via Agent Activity
Greetings!
I would like to know how to create a single work case via an agent activity.
Currently, I have created an agent activity in the relevant Work class. In the activity I have called the createWorkPage (defined a temp page of the relevant work class, and set this as the pyWorkPage param), AddWork and then the CommitWithErrorHandling activities with the temp page as the step page.
I validated the functionality of the activity by dry-running it. In this case the case is created without an issue. But I see no cases created by the agent.
The agent is of type standard. The agent shedule has "Bypass activity authentication" ticked, so there shouldn't be a problem there.
Please note that at this moment I have no SMA access, so tracing the agent is out of the question.
Is the method I used correct? Or am I doing something wrong?
Appreciate any feedback.
Cheers,
Lahiru.
