Getting empty values when referencing a property directly in Word Template
I am working on a requirement where I have to generate word document from a Word template.
I am trying to create Word Document using pzGenerateDocument RUF (as per solution mentioned in https://pdn.pega.com/community/pega-product-support/question/generate-word-document-using-word-document-which-can-show).
I am facing one problem, If I do a property reference for eg: {pega:reference .PropertyName} directly in the WordTemplate, I am not getting any value.
But If I refer same property inside the Corr rule then I can see the Value. (See the attachment)
Note: If I Refer a property inside a Corr rule and insert the corr in WordTemplate, I am able to see the value.
Property reference through {pega:insert corr=CorrName} is working
Direct properrty reference {pega:reference .PropertyName} is not working, returning empty value.
I also found this link https://pdn.pega.com/support-articles/word-merge-does-not-pull-pegareference-fields-template. Not sure this is the actual Root cause for my issue also.
Am I missing anything here? Need your Kind Help!!
Thanks in Advance
***Updated by Moderator: Lochan. Removed user added Ask the Expert and helpme tags. Apologies for confusion, shouldn't have been an end-user option; edited Category***
Thanks in Advance
