How to run a thorough validation pre/post migration?
Here's an article from 6+ years ago on PDN: https://pdn.pega.com/system-operations/how-to-revalidate-all-rules-in-a-ruleset
"Using a list view report on rules, a 5-step activity, and an HTML rule, you can revalidate all rules in one RuleSet, one RuleSet version, or a specific list of RuleSet versions..."
That's a lot of work which is probably no longer necessary. This article should probably be updated/replaced.
Here's my survey of the rule validation tools which I've put on our own intranet:
- Revalidate for References - Validates by Ruleset/Name. Runs synchronously in main thread.
- Revalidate and Save Instances - Runs per Class (pxObjClass) -- makes updates to history/pxUpdate* properties (unnecessarily!)
- Static Assembler - Was available in commandline through v6.2; via Developer Dashboard in v6.3+ . Runs asynchronously. Creates log file of validation failures for download (with stacktraces)
After doing a migration, it is prudent to revalidate the AccessGroups, to ensure that the application rules & roles are updated as well.
This is important since an accessgroup failure could well be catastrophic, preventing user login, or even preventing system startup (for AccessGroups used by Data-Admin-Requestors)
***Updated by moderator: Marissa to close post***
