Is there an API call to pull child case from a top level case?
We are looking for an API that will pull a child case from a top level case, and that former child case becomes a top level case.
not sure, but could you please refer the below OOTB API's
Not an API call, but there is OOTB activity, pzGetDescendants.
You can see an example of it's use in pxForceCaseClose.
Edit: sorry just saw the second half of the question, you could then utilise activity, RemoveFromCover.
