Cognizant
Cognizant
Cognizant
Posted: Dec 3, 2015
Last activity: Dec 4, 2015
Last activity: 4 Dec 2015 2:26 EST
There is already a OOTB RD- "pyAverageElapsedTimePerStatus". But i am unable to understand how to utilize this? Can anyone suggest the possible approach
Do you mean that it is not retrieving any results on running the above rd ? can you elaborate on point 'how to utilize this' ?
Hi Haritha Damarla, I meant it was not returning any results, so i have a doubt whether this RD requires any input parameters like wise. As per the article you shared below and Karthik Veerlapati comments i made pyTrackStatus When rule to return true. Now are there any additional parameters required that i need to give to fetch the results or its just enough?
Hi.
It is a report where User can track time in each status for each work item.
Karthik Veerlapati may be you can elaborate it a little here.
Thanks in advance.
“pyAverageElapsedTimePerStatus” Report Definition displays the Average elapsed time of a Status and user can drill down to view the details. For this to work "pyTrackStatus" when rule should be overridden and make it to return true.
