![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689984000/19313df3-1af4-4906-9912-246921407958.jpg?itok=eWtf2Si5)
TATA CONSULTANCY SERVICES
Last activity: 27 Jan 2016 23:47 EST
Hung Threads - Does Pega uses SoapConnectorThreadPool ?
We are observing few hung threads in the JVM & found that those hung threads are related to Pega. As per the Stacktrace looks like - Pega OOTB MBean operation to get the RequestorList Size was invoked.
Few Questions........
1) Does Pega make use of Websphere - SoapConnectorThreadPool ?? If yes, in which all Scenarios/functionalities does Pega makes use of this Thread Pool. I'm only aware of WebContainer Threads.
2) Is there any recommendation from pega on what size does the SoapConnectorThreadPool should be ?
3) Looking at this log - can anyone tell whether thsi MBean Operation invoked manually (I mean may be someone was using SMA at that timeframe ?) or what other actions/applications would have triggered this Request ?
at com.pega.pegarules.management.internal.RequestorManagement.RequestorListWithSize(RequestorManagement.java:133)
[12/22/15 21:37:23:001 MST] 00000003 ThreadMonitor W CWWSR0605W: Thread "SoapConnectorThreadPool : 23" (00000072) has been active for 603481 milliseconds a
nd may be hung. There is/are 1 thread(s) in total in the server that may be hung.
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.estimateDataSize(ClipboardPageImpl.java:5021)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.estimateDataSize(ClipboardPropertyImpl.java:862)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.estimateDataSize(ClipboardPageImpl.java:4993)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.estimateDataSize(ClipboardPropertyImpl.java:855)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.estimateDataSize(ClipboardPageImpl.java:4872)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.estimateDataSize(ClipboardPageImpl.java:4868)
at com.pega.pegarules.session.internal.mgmt.base.handler.UserPageHandler.estimateDataSize(UserPageHandler.java:201)
at com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.estimatePageDirectoryDataSize(AbstractPageDirectory.java:1345)
at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.estimateDataSize(ThreadPageDir.java:808)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.estimateDataSize(PRThreadImpl.java:1112)
at com.pega.pegarules.session.internal.mgmt.base.RequestorPageDir.estimateDataSize(RequestorPageDir.java:214)
at com.pega.pegarules.session.internal.mgmt.PRRequestorImpl.estimateDataSize(PRRequestorImpl.java:1559)
at com.pega.pegarules.management.api.PegaRequestorManagementImpl$2.run(PegaRequestorManagementImpl.java:281)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doUnsafeAccessToUnlockedRequestor(PRSessionProviderImpl.java:509)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doUnsafeAccessToUnlockedRequestor(PRSessionProviderImpl.java:465)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doUnsafeAccessToUnlockedRequestor(PRSessionProviderImpl.java:2006)
at com.pega.pegarules.management.api.PegaRequestorManagementImpl.getRequestorList(PegaRequestorManagementImpl.java:218)
at com.pega.pegarules.management.internal.RequestorManagementAPI.RequestorList(RequestorManagementAPI.java:308)
at com.pega.pegarules.management.internal.RequestorManagementAPI.RequestorList(RequestorManagementAPI.java:284)
at com.pega.pegarules.management.internal.RequestorManagementAPI.RequestorListWithSize(RequestorManagementAPI.java:276)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.pega.pegarules.management.internal.MB2EngineAccess.invoke(MB2EngineAccess.java:169)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invoke_privact(EngineImpl.java:364)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.run(EngineImpl.java:349)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1177)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:926)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:777)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:323)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:238)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.management.internal.MBeanHelper.invokeOperation(MBeanHelper.java:77)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:69)
at sun.reflect.GeneratedMethodAccessor57.invoke(Unknown Source)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:272)
at javax.management.modelmbean.RequiredModelMBean$4.run(RequiredModelMBean.java:1152)
at java.security.AccessController.doPrivileged(AccessController.java:384)
at com.ibm.oti.security.CheckedAccessControlContext.securityCheck(CheckedAccessControlContext.java:30)
at sun.misc.JavaSecurityAccessWrapper.doIntersectionPrivilege(JavaSecurityAccessWrapper.java:41)
at javax.management.modelmbean.RequiredModelMBean.invokeMethod(RequiredModelMBean.java:1146)
at javax.management.modelmbean.RequiredModelMBean.invoke(RequiredModelMBean.java:999)
at com.pega.pegarules.priv.management.PegaModelMBean.invoke(PegaModelMBean.java:121)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:847)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:783)
at com.ibm.ws.management.AdminServiceImpl$1.run(AdminServiceImpl.java:1346)
at com.ibm.ws.security.util.AccessController.doPrivileged(AccessController.java:118)
at com.ibm.ws.management.AdminServiceImpl.invoke(AdminServiceImpl.java:1239)
at com.ibm.ws.management.connector.AdminServiceDelegator.invoke(AdminServiceDelegator.java:181)
at com.ibm.ws.management.connector.soap.SOAPConnector.invoke(SOAPConnector.java:464)
at com.ibm.ws.management.connector.soap.SOAPConnector.service(SOAPConnector.java:297)
at com.ibm.ws.management.connector.soap.SOAPConnection.handleRequest(SOAPConnection.java:65)
at com.ibm.ws.http.HttpConnection.readAndHandleRequest(HttpConnection.java:733)
at com.ibm.ws.http.HttpConnection.run(HttpConnection.java:522)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1662)
Hari Kumar Alampuru
