navistar
Last activity: 14 Dec 2016 9:05 EST
Hung threads on one jvm while starting websphere application server with pega7.1.9 installed on it
Pega7.1.9 installed on webpshere Proprietary information hidden cluster with two jvms, MSSQL is the DB.
While starting the application server only one jvm reporting these hung threads and taking very unusual time to comeup when compared to the other jvm.
Can someone please tell me why?
[11/10/16 16:36:22:654 CST] 000000e7 ThreadMonitor W WSVR0605W: Thread "server.startup : 2" (00000086) has been active for 707114 milliseconds and may be hung. There is/are 1 thread(s) in total in the server that may be hung.
at com.ibm.ws.runtime.component.DeployedApplicationImpl.start(DeployedApplicationImpl.java:985)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplication(ApplicationMgrImpl.java:776)
at com.ibm.ws.runtime.component.ApplicationMgrImpl$5.run(ApplicationMgrImpl.java:2195)
at com.ibm.ws.security.auth.ContextManagerImpl.runAs(ContextManagerImpl.java:5477)
at com.ibm.ws.security.auth.ContextManagerImpl.runAsSystem(ContextManagerImpl.java:5603)
at com.ibm.ws.security.core.SecurityContext.runAsSystem(SecurityContext.java:255)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:2200)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.start(CompositionUnitMgrImpl.java:435)
at com.ibm.ws.runtime.component.CompositionUnitImpl.start(CompositionUnitImpl.java:123)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.start(CompositionUnitMgrImpl.java:378)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.access$500(CompositionUnitMgrImpl.java:126)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl$CUInitializer.run(CompositionUnitMgrImpl.java:984)
at com.ibm.wsspi.runtime.component.WsComponentImpl$_AsynchInitializer.run(WsComponentImpl.java:502)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1881)
[11/10/16 16:36:22:702 CST] 000000e7 ThreadMonitor W WSVR0605W: Thread "server.startup : 1" (00000085) has been active for 707118 milliseconds and may be hung. There is/are 2 thread(s) in total in the server that may be hung.
[11/10/16 16:36:22:757 CST] 000000e7 ThreadMonitor W WSVR0605W: Thread "brksvx247d.ad.navistar.com" (00000084) has been active for 707113 milliseconds and may be hung. There is/are 3 thread(s) in total in the server that may be hung.
at org.eclipse.jdt.internal.compiler.flow.UnconditionalFlowInfo.copy(UnconditionalFlowInfo.java:650)
at org.eclipse.jdt.internal.compiler.ast.MessageSend.analyseCode(MessageSend.java:188)
at org.eclipse.jdt.internal.compiler.ast.UnaryExpression.analyseCode(UnaryExpression.java:41)
at org.eclipse.jdt.internal.compiler.ast.IfStatement.analyseCode(IfStatement.java:62)
at org.eclipse.jdt.internal.compiler.ast.Block.analyseCode(Block.java:48)
at org.eclipse.jdt.internal.compiler.ast.IfStatement.analyseCode(IfStatement.java:105)
at org.eclipse.jdt.internal.compiler.ast.IfStatement.analyseCode(IfStatement.java:133)
at org.eclipse.jdt.internal.compiler.ast.MethodDeclaration.analyseCode(MethodDeclaration.java:124)
at org.eclipse.jdt.internal.compiler.ast.TypeDeclaration.internalAnalyseCode(TypeDeclaration.java:737)
at org.eclipse.jdt.internal.compiler.ast.TypeDeclaration.analyseCode(TypeDeclaration.java:261)
at org.eclipse.jdt.internal.compiler.ast.CompilationUnitDeclaration.analyseCode(CompilationUnitDeclaration.java:118)
at org.eclipse.jdt.internal.compiler.Compiler.process(Compiler.java:776)
at org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler.java:470)
at org.eclipse.jdt.internal.compiler.batch.Main.performCompilation(Main.java:4129)
at org.eclipse.jdt.internal.compiler.tool.EclipseCompilerImpl.call(EclipseCompilerImpl.java:76)
at org.eclipse.jdt.internal.compiler.tool.EclipseCompiler$1.call(EclipseCompiler.java:185)
at com.pega.jsr199.Jsr199Bridge.compile_impl(Jsr199Bridge.java:277)
at com.pega.jsr199.Jsr199Bridge.compile(Jsr199Bridge.java:209)
at sun.reflect.GeneratedMethodAccessor56.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.pega.pegarules.generation.internal.compiler.PRCompilerPoolImpl$Eclipse34BridgeClassInfo.invokeCompiler(PRCompilerPoolImpl.java:182)
at com.pega.pegarules.generation.internal.compiler.PRCompilerEclipse._compile_privact(PRCompilerEclipse.java:581)
at com.pega.pegarules.generation.internal.compiler.PRCompilerEclipse.compile(PRCompilerEclipse.java:503)
at com.pega.pegarules.generation.internal.library.LibraryFunctionUtilityImpl.compileLibraryAndFunctions(LibraryFunctionUtilityImpl.java:2711)
at com.pega.pegarules.generation.internal.library.LibraryFunctionUtilityImpl.generateLibrary(LibraryFunctionUtilityImpl.java:1105)
at com.pega.pegarules.generation.internal.library.LibraryFunctionUtilityImpl.extractAll(LibraryFunctionUtilityImpl.java:452)
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.handleExtraction(PRNodeImpl.java:1603)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.finishInit(PREnvironment.java:509)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1270)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:841)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:382)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:1998)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:664)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:165)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:138)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.doStartup(EngineBean.java:121)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.doStartup(EngineBeanBoot.java:130)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.doStartup(Unknown Source)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:311)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextInitialized(WebAppLifeCycleListener.java:218)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at com.ibm.ws.webcontainer.webapp.WebApp.notifyServletContextCreated(WebApp.java:1707)
at com.ibm.ws.webcontainer.webapp.WebAppImpl.initialize(WebAppImpl.java:411)
at com.ibm.ws.webcontainer.webapp.WebGroupImpl.addWebApplication(WebGroupImpl.java:88)
at com.ibm.ws.webcontainer.VirtualHostImpl.addWebApplication(VirtualHostImpl.java:170)
at com.ibm.ws.webcontainer.WSWebContainer.addWebApp(WSWebContainer.java:904)
at com.ibm.ws.webcontainer.WSWebContainer.addWebApplication(WSWebContainer.java:789)
at com.ibm.ws.webcontainer.component.WebContainerImpl.install(WebContainerImpl.java:427)
at com.ibm.ws.webcontainer.component.WebContainerImpl.start(WebContainerImpl.java:719)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:1177)
at com.ibm.ws.runtime.component.DeployedApplicationImpl.fireDeployedObjectStart(DeployedApplicationImpl.java:1382)
at com.ibm.ws.runtime.component.DeployedModuleImpl.start(DeployedModuleImpl.java:639)
at com.ibm.ws.runtime.component.DeployedApplicationImpl.start(DeployedApplicationImpl.java:971)
Thanks!
***Moderator Edit: Vidyaranjan| Updated Categories***
