Common Wealth Bank of Australia
Last activity: 3 Feb 2016 20:10 EST
Pega 7.1.9 - Localize values are not reflected
I have created a localize value for pyStatusWork in my application class and used it in the sections specific to my application. But the localize values are not getting reflected in the sections/harness
I have checked the following things:
Property reference in Section looks like below:
All the harnesses and sections have the below settings enabled:
But, still on the screen when I create a work object , the localized values are not reflected.
Am I missing any additional configuration anywhere else?
Infosys
Using control "GetLocalizedValue" worked for me.
Following is the help for field values:
Functions for localization
These standard rules support localization based on field values: (In most cases, automatically generated facilities call these functions in the appropriate places; you do not need to reference them explicitly.)
- Activity @baseclass.GetLocalizedTextForString
- Function getLocalizedValue() in the PegaRULES String library
- Function getLocalizedText() in the PegaRULES Utility library
- Control rule GetLocalizedValue
(My thoughts: That's PRPC for me By theory I assume/understand something, practically it turns out be something else)
Hope this helps you!
Murali...
Virtusa
Hi Srividhya,
In the screenshot i could see that, the label field is blank. May i know why it is.
If you have created a localized labels, try to open it from the section using open rule, from label.
Correct me if my understanding is wrong.
Thanks.
Pegasystems
Please trace so you can check three things:
1) The generated stream code that renders the field value associated with the contents of the status property, is it calling something like GetLocalizedText ? This shows whether the "localize" mode is actually in effect.
2) If the parameter being passed to GetLocalizedText (or whatever it's called) correct for the field value you expect ?
3) Show your pxThread page as the step page in at least one of your tracer lines (use private-checkout if you have to add an activity line somewhere) so you can bring up that pxThread page from the tracer to look in pxSecuritySnapshots - > pxUserRulesetsLocalized, so you can make sure all your rulesets, particularly the language-specific ones, are being included in the list.
/Eric
Hi Eric,
Thanks for your detailed reply,
Following are my observations:
1)The property is defined in a section and I could not verify the stream code - I can't see the GetLocalizedText method being invoked anywhere. Can you please guide on how can we view the generated stream for a section.
2) Parameter value being passed is exactly the same as the value defined in the Field Value. But I think, this verification depends on the above point 1.
3) I have verified and can see all the rulesets associated with my application is available in the localized ruleset stack
Hi Arul,
Thanks for the reply.
I need to only display the localized value of the property and doesn't want any label to be displayed. Hence, the label property is empty.
Sri
Infosys
Murali...
Thanks a lot Murali, that did the trick for me too.
I sort of agree with your thoughts .
Infosys
No worries. Glad that "GetLocalizedValue" control worked for you.
Murali...
I had to display the text in a specific format and hence used the formatted text (It is weird on why the value - Localize Property Value did not work), but with the GetLocalizedValue we can't use any control formats , Hence had to go with the inline-style now.
