Realvalue Consulting
IT
Last activity: 24 Feb 2016 12:37 EST
SR - Add a customer
Hi everyone, we need to open an SR for a customer which is not visible in the Company drop down menù of a SR window. Which is the right procedure to follow to add a customer?
Stefano,
If you need to submit an SR, please do so via the My Support Portal (https://collaborate.pega.com/question/how-raise-sr-my-support-portal-how-question). If you are with a Pega partner, and don't see an option for the end customer that you're working with, just mention that in the SR description, and the engineer who triages the SR can take care of that.
Let me know if you have any other questions.
Cheers!
Updated: 24 Feb 2016 7:53 EST
Hi Stefano,
Do you need to raise an SR with Pega Product Support? Are you trying to create an SR here - https://collaborate.pega.com/question/how-raise-sr-my-support-portal-how-question
IT
Hi Lochana,
Thank you very much for your quick feedback.
Yes; I confirm that we need to raise an SR with Pega Product Support?
Regards
Stefano
Hi Stefano,
Thanks for confirming!
In this case would you mind contact Pega Product Support through any of the contact numbers provided in this link: https://pdn.pega.com/support-contact-information
I found this in My Support Portal > Resources > Contact Support
Let me know if this helped!
Lochan
IT
Hi Lochan,
I phoned to EMEA Pega Product Support and I was told to contact our Local PEGA Team in order to address the issue.
Regards
Stefano
Stefano,
Cheers!
IT
HI David,
Thank you so much for your response.
We will follow your suggestion.
Regards
Stefano
