Pega 7.1.8 Installation on SQL Server Issue
I'm getting below error when I try to Install pega 718 on SQL Server.
Engine Load Inner:
[java] 2016-02-25 17:22:44,991 (com.pega.pegarules.internal.bootstr) 19830421 - Loading bootstrap properties from file:///C:\Users\abusyed\AppData\Local\Temp\/PegaInstallTemp-25-February-2016-17.22.32/prbootstrap.properties
[java] 2016-02-25 17:22:45,000 (com.pega.pegarules.internal.bootstr) 19830421 - Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
[java] 2016-02-25 17:22:45,000 (com.pega.pegarules.internal.bootstr) 19830421 - Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
[java] 2016-02-25 17:22:45,001 (com.pega.pegarules.internal.bootstr) 19830421 - Engine schema defined in allclasses: null
[java] 2016-02-25 17:22:45,001 (com.pega.pegarules.internal.bootstr) 19830421 - Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
[java] 2016-02-25 17:22:45,002 (com.pega.pegarules.internal.bootstr) 19830421 - Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
[java] 2016-02-25 17:22:45,002 (com.pega.pegarules.internal.bootstr) 19830421 - Engine classes schema: null
[java] 2016-02-25 17:22:45,002 (com.pega.pegarules.internal.bootstr) 19830421 - Assembled classes schema: null
Engine Load Inner:
[java] com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'RULES.pr_engineclasses'.
[java] at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:216)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1515)
[java] at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:404)
[java] at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:350)
[java] at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:5696)
[java] at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1715)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:180)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:155)
[java] at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:285)
[java] at com.pega.pegarules.configdbcp.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:99)
[java] at com.pega.pegarules.internal.bootstrap.phase2.jdbc.JdbcJarWriter$WriteConnection.verifyConnection(JdbcJarWriter.java:928)
[java] at com.pega.pegarules.internal.bootstrap.phase2.jdbc.JdbcJarWriter.<init>(JdbcJarWriter.java:823)
[java] at com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool.initDBConnection(JarLoaderTool.java:1833)
[java] at com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool.mainImpl(JarLoaderTool.java:1371)
[java] at com.pega.pegarules.internal.bootstrap.phase2.util.JarLoaderTool.main(JarLoaderTool.java:1129)
[java] 2016-02-25 17:22:46,209 (com.pega.pegarules.internal.bootstr) WARNING - Database not configured or usable for storing classes.
I did a PDN search and came across similar error message but that was for oracle and it says some Grants missing. Did anyone face similar issues.
