How can be not found rule that located in @baseclass ?
There are several error messages like this:
(ternal.mgmt.StreamBuilderTools) ERROR sbld-sup.bpm.lanit sbld-research.bpm.lanit #UserName# - Could not find a rule when appending a stream com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find instance @baseclass.CoveredHeaderForReview of type Rule-Obj-HTML.
As I had read this means that rule was not found because the primary page was not found. (The attempt to generate stream rule was failed)
Can you please suggest any solutions or/and scenarios to reproduce problem?
