SINARMASMSIGLIFE
ID
Failed to find a 'RULE-OBJ-MODEL' with the name 'PYDEFAULT' that applies to '@baseclass'
hi,
I found a problem with this issued, before I found an error like this.
and then i using SMA (as recommended in this link) : https://collaborate.pega.com/question/failure-opening-rule-instance-error-baseclass
but not successful ( still cannot open),
and then i delete class from refactor but still not deleted.
hi,
so i create again this class, but when at last step ( after click finish) , there are something error .
i got error message "PYCOMMIT error :Failed to find a 'RULE-OBJ-MODEL' with the name 'PYDEFAULT' that applies to :'ClassPath.PYDEFAULT".
after that, i got error whenever try to open others class .
there is message error in tracer :
Failed to find a 'RULE-OBJ-MODEL' with the name 'PYDEFAULT' that applies to '@baseclass'. There were 1280 rules with this name in the rulebase, but none matched this request. The 1280 rules named 'PYDEFAULT' defined in the rulebase are:
1252 related to applies-to class '@baseclass', but were defined on subclasses: {Data-MO-DDF-Compose, Rule-Parse-Infer, Rule-Test-Unit-Case, PegaAccel-Task-AttachmentCategory, Rule-Template-Word, Log-DataAccessAudit, Embed-Skin-Component, PegaAccel-Task-Harnesses, PegaGadget-InformationMashup, Data-Corr-PhoneText, Rule-Service-MQ, Embed-SelectedContextAPI-AddRow, Data-Admin-Security-Keystore, Embed-DesktopAPI-ShowWorkList, PegaFW-Data-SocialFilter, Embed-SelectedContextAPI-RunDataTransform, Data-MO-DSM-StrategySet, Embed-FConditions, PegaAccel-Task-ImportExport-Requirements, Embed-Stencil-Presentation-Modifier,...}.
28 inaccessible because their availability was {No, Withdrawn, Blocked}.
can you/anyone help me ?
Hi
That is interesting. This is an out of the box rule and should be present under the said ruleset . I can see that present at my end .
Its good that you crated your own version and that solved the issue but you need to introspect that how the out of the box file goes missing in your application.
