Failed to find a 'RULE-OBJ-CASETYPE' with the name 'PYDEFAULT' that applies to '@baseclass'
hi,
I found a problem when trying to submit a flow action. In the flow action post processing activity, there is a call to CreateWorkPage activity and in the activity step 10 in tracer, I see the below error:
But if i run the flow action again for the 2nd time, there is no error and the form submits.
the flow action post processing activity failed:Failed to find a 'RULE-OBJ-CASETYPE' with the name 'PYDEFAULT' that applies to :'"@baseclass". There were 336 rules in the rulebase but none matched the request. the 336 rules named defined in the rulesbase are: 335 related to applied to clases: X,Y,Z etc 1 inaccessible because their availability was withdrawn
anyone faced similar issue and can share the fix please?
