Rules Cube Inc.
How to move data types to different instances
I have a data type (formerly data table) and want to move it to different instance. Please let me know how it can be done. i could not see the data instance pzinskey in data table actions button as shown below.
Venkatesh G.
Hi Venkatesh,
You could create a Product file with just the 'Class instances to include' section completed. You can leave the 'Applications to include' and 'RuleSets to include' sections blank if you do not need any of those rules.
Carissa
what version of prpc is this? Is this always reproducible?
Rules Cube Inc.
Hi Kevin
Pega 7.2
Yes it's reproducible always..
Venkatesh G
this is the case even after you follow Carissa's suggestion?
Hi Venkatesh,
If you use the Application Packaging wizard there is a step to select the data tables you would like to include in the Product file. When viewing the Product rule generated you will see the class listed in the "Class instances to include" section.
Carissa
Rules Cube Inc.
Hi Carissa,
Thank you for your reply, my requirement is to pull only data types into one rap file. I don't need entire application package.
Venkatesh G.
Truviq Systems
HI venkatesh,
As i know, Data Type is not a separate instance from Class.
Make sure that associated Data pages, Database Table Rules instances were included.
--Chaitanya
Hi Venkatesh,
Carissa
Novitates
i have added class name in (Class instances to include' section) Product file and imported that jar in new environment but not able to find the data type.
Can any one suggest the approach.
Thanks in Advance
Vikram
@Vikram22 if you try with the suggestion provided by Carissa then perform the export of the Product rule then perform the import it should work or you can try to add the DATA-ADMIN-DB-TABLE for the data type as shown in the attachment then have a try.
Camila Andrea Estupinan Guevara
Novitates
Hi Naresh,
Thanks for your response, i have included class instance and Table instance in Product rule but still not able to find the data type.
Vikram
@Vikram22 if you don't mind could you please share the screenshots of the Product rule and import wizard to make sure what is happening during import.
