Bank Of America
BIX- Extract rule throwing : Status Fail
Hi
Couple of days back installed BIX and it was running fine. Created 2/3 Extract rule and everything going on track.
Last tow days when I tried to open Extract rule. Rule is not opening and displaying below message.
Status fail
Message There has been an issue; please consult your system administrator
Operator ID Ravi
Requestor ID H0E060EF73CBCD273F31E11187F002D69
Timestamp Wed Mar 16 06:10:01 EDT 2016
Engine Version PegaRULES 7.10 ML8 (coreAssemblyCached_718_675)
Pega PRPC Version : 7.1.8
Ravi Mishra
Pegasystems
Are there any exceptions in the log file? Please share the log file.
Bank Of America
Can't copy entire log but the error message is:
Caused by:
java.lang.NoClassDefFoundError: com/pegarules/generated/pega_bix_bix
Pegasystems
You can attach the log file to this post (zip and attach)
Bank Of America
There is security violation with org
Pegasystems
Without the full stack trace, it is difficult to figure out the issue. If this is a security concern for your organization, please raise an SR and GCS could do a screen share with you figure out the problem. I am assuming this is probably related to bix library not getting compiled correctly. Can you open the bix library rule and try compiling it?
Bank Of America
Excepting it's some problem with BIX lib only. Because other rules are opening properly.
Bank Of America
Can you let me know where I can find this BIX lib details. So I can compile it .
Pegasystems
You can search for the following rules and hit generate library for them and then check if the error gets resolved.
RULE-UTILITY-LIBRARY PEGABIX PEGA-BIX
RULE-UTILITY-LIBRARY BIX PEGA-BIX
Bank Of America
There is no Library as such exist. surprise......
One important point my extract rules was working fine couple of days back.
Today i tried to re-import but the BIX zip/jar is already exist.
Pegasystems
Does your current application have the Pega-BIX ruleset? If yes, when you look at the instance list for Rule-Utility-Library, these two are not visible?
Bank Of America
yes Pega-BX is available. Added to App rule set list.
I have created couple of Extract rule everything was fine.....last couple of days these issue is raising
BIX related there is no Library.
Pegasystems
Do you have any Rule-Utility-Function in the Pega-BIX ruleset?
Bank Of America
I will check each version and see
Bank Of America
there are some functions.
Example : But surprise I am not getting BIX Lib
Pegasystems
Are you using BIX from the "additional products" of the Pega 7.1.8 distribution image?
Also, can you try re-importing the BIX ruleset again?
Bank Of America
Yes,
Not able to re-import always says its there
Pegasystems
What is the highest ruleset version of Pega-BIX ruleset? Is it 07-10-17?
Bank Of America
yes
Pegasystems
Please raise a SR with Pega with this details. It definitely looks like the import of BIX did not happen correctly leading to this issue.
Bank Of America
This is all the list of Lib
| BAC_LIB | BAC |
| DateTime | Pega-RULES |
| Default | Pega-IntegrationEngine |
| Default | Pega-ProCom |
| Default | Pega-RULES |
| Default | Pega-RulesEngine |
| ECF_LIB | ECF |
| Math | Pega-RULES |
| Sort | Pega-RULES |
| String | Pega-RULES |
| String | Pega-RulesEngine |
| Utilities | Pega-AppDefinition |
| Utilities | Pega-ProcessArchitect |
| Utilities | Pega-RULES |
| Utilities | Pega-RulesEngine |
Hi Ravi,
Please let us know the SR number here if you end up opening one.
Lochan
Accenture Australia Ltd
Hi Guys,
We've a similar issue here. For a while, we have been working with Extract rules in Dev environment and all of sudden we arent able to open up any extract rules from the designer studio in Dev. A RSV Pega-BIX (Pega-BIX:07-10-23) is in the App stack, PRPC version is V7.2 and no changes done to prconfig.xml/DSS settings.
Did anyone else face the similar issue?
The log file exception is as following;
Hi Guys,
2017-12-06 08:36:15,875 [ WebContainer : 3] [TABTHREAD1] [ VZWCSCBIX:01.01.01] (ngineinterface.service.HttpAPI) ERROR rtd-dev1-aws.ebiz.verizon.com| Proprietary information hidden feroz - Proprietary information hidden: com.pega.pegarules.pub.PRRuntimeError com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:712) at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:466) at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3093) at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:390) at sun.reflect.GeneratedMethodAccessor78.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56) at java.lang.reflect.Method.invoke(Method.java:620) at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1277) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1015) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:848) at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331) at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:817) at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:327) at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:270) at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:247) at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278) at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223) at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:574) at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:374) at sun.reflect.GeneratedMethodAccessor76.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56) at java.lang.reflect.Method.invoke(Method.java:620) at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370) at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411) at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224) at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273) at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121) at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:92) at javax.servlet.http.HttpServlet.service(HttpServlet.java:575) at javax.servlet.http.HttpServlet.service(HttpServlet.java:668) at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1232) at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:781) at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:480) at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178) at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1114) at com.ibm.ws.webcontainer.webapp.WebApp.handleRequest(WebApp.java:3951) at com.ibm.ws.webcontainer.webapp.WebGroup.handleRequest(WebGroup.java:304) at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:1014) at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817) at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:200) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:463) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:530) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:316) at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:88) at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175) at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217) at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161) at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138) at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204) at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775) at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905) at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1892) Caused by: java.lang.NoClassDefFoundError: com/pegarules/generated/pega_bix_bix at com.pegarules.generated.activity.ra_action_opendefaults_6892f1376ab4e9276f31902230b97fa7.step1_circum0(ra_action_opendefaults_6892f1376ab4e9276f31902230b97fa7.java:166) at com.pegarules.generated.activity.ra_action_opendefaults_6892f1376ab4e9276f31902230b97fa7.perform(ra_action_opendefaults_6892f1376ab4e9276f31902230b97fa7.java:69) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3510) at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10587) at com.pegarules.generated.activity.ra_action_open_93051fba4e89837e9e148708381e5bbf.step6_circum0(ra_action_open_93051fba4e89837e9e148708381e5bbf.java:470) at com.pegarules.generated.activity.ra_action_open_93051fba4e89837e9e148708381e5bbf.perform(ra_action_open_93051fba4e89837e9e148708381e5bbf.java:160) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3510) at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10587) at com.pegarules.generated.activity.ra_action_open_f65d1a522b38fce846937de18d90faf4.step3_circum0(ra_action_open_f65d1a522b38fce846937de18d90faf4.java:166) at com.pegarules.generated.activity.ra_action_open_f65d1a522b38fce846937de18d90faf4.perform(ra_action_open_f65d1a522b38fce846937de18d90faf4.java:70) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3510) at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10587) at com.pegarules.generated.activity.ra_action_wbopen_2d908a5a78b94d75a5b5dceb1cf80a33.step18_circum0(ra_action_wbopen_2d908a5a78b94d75a5b5dceb1cf80a33.java:1880) at com.pegarules.generated.activity.ra_action_wbopen_2d908a5a78b94d75a5b5dceb1cf80a33.perform(ra_action_wbopen_2d908a5a78b94d75a5b5dceb1cf80a33.java:411) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3510) at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10587) at com.pegarules.generated.activity.ra_action_douiaction_a5ee0f731bbd33ad6fec4e0ed526b717.step28_circum0(ra_action_douiaction_a5ee0f731bbd33ad6fec4e0ed526b717.java:2905) at com.pegarules.generated.activity.ra_action_douiaction_a5ee0f731bbd33ad6fec4e0ed526b717.perform(ra_action_douiaction_a5ee0f731bbd33ad6fec4e0ed526b717.java:526) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3510) at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646) ... 51 more
