Available for hire
CH
Last activity: 29 Mar 2016 9:56 EDT
Dropdown, first item cannot be selected
Hello, i have an issue with the dropdown functionality. My case is that i have a dropdown populated by data page. Everything works perfect to the point where i select the first element from the list. It results impossible,, If i select any other element it is ok , once i try to select the first one it reverts to the last selected element or it shows empty field if i try do to it right after loading the screen. In my section i have two different dropdowns that are using two different data pages and the behavior is the same. They are set to get loaded on user hover. The version of the pega is 7.1.8.
Hi
This sounds little weird. How about setting a default value in the drop down ,like "Please select" ? In that way you can probably get rid of the issue .
