Multi Select Dropdown
I am using multi select drop down, My issue here is if the drop down has values with similar wordings as "Active Equity RCB" and "Active Equity" as drop down values, if I select "Active Equity RCB" from the multi select drop down the second value i.e., "Active Equity" is getting disappeared from the drop down list.
Can any one provide me solution for this.
Bindu B.
