Self
Last activity: 21 Apr 2016 6:19 EDT
Reverse Proxy
Requiement is :
1. Whenever users launch the Pega from IPAD using a different URL there will be a reverse proxy setting configured at the different application server to re-direct it to the Pega application server
2. For the same user if he launches the URL from desktop Pega URL will be given to them
Queries:
1. Is it possible to set up a reverse proxy set up for Pega 7 and does it require any additional changes in Pega.
2. If we setup the reverse proxy does it have any impact on the normal Pega URL launch Please highlight any concerns and gives us the procedure/steps if there are any to do this configuration
You can start with this : https://pdn.pega.com/how-configure-reverse-proxy-server
Self
I wasnt able to open the link and it is giving me access denied error - can you help to repost the link?
Also you can check this thread
Self
Same issue with this link also
Updated: 8 Apr 2016 6:48 EDT
Hi Manoj,
I just checked and I am able to access those links.
Pasting them again
https://mesh.pega.com/message/216527
Best Regards,
Mounika
Self
HI Mounika,
Access denied to see that page and possible to paste the content here or you can send me an email ?
Manoj
Self
Hi All ,
Still i am not able to access the link - it says access denied to my ID
Manoj
Hi Manoj,
Sorry for the response delay.
Attaching the discussion/content.
Best Regards,
Mounika
Self
Hi Mounika - I tried the approach in the PRCONFIG.XML as Pega 7 don't have PegaRULES.XML , but redirection doesn't work
Let me know if any details required or any other config which I need to do apart from below , below is the config which I did in the PRCONG.XML
<node name= "Initialization" label= "Initialization"/>
<map>
<entry key= "SetBaseHTMLContext"
value="http://UWARMADOS0A:5245"/>
<entry key= "ContextRewriteEnabled" value="true"/>
</map>
Thanks.
