Last activity: 23 Jun 2017 7:31 EDT
Customising dashboard per accessgroup
I tried to customise dashboard for each accessgroup in my application by following the steps below -
- Create two new harness rules in Data-Portal class by copying pyCaseManager7
- Create two new composite portals and refer the newly created harness
- Launch the newly created portals from admin access group and make alterations in each dashboard by adjusting the widgets after switching to edit mode by clicking the gear icon
- Publish to default after making alterations in each dashboard one by one.
- Re-login using operator ids of different access groups and test the portals.
However, I could see that the unique alterations done to the second portal is also reflected in the first portal.
Is there any way to customise each portal differently in the same application using the widgets in edit mode ?
Or do I need to add the section(corresponding to each widget) separately in different harnesses to show different views ?
I am using prpc 7.1.9
Thanks.
