Accenture Services Pvt Ltd
Last activity: 24 Jun 2016 13:40 EDT
Pega 7.1.9 rulebase installation on DB2 failed
I was trying to install PRPC7.1.9 rulebase on DB2 10.5. This is a fresh installation, not an upgrade. But while running the installation I got the below error. Please suggest.
java] 2016-06-24 05:28:55,069 ( SQLLoader) INFO - CREATE INDEX PRPCUSER.PR_DATA_TOKEN_IDX1
[java] 2016-06-24 05:28:55,172 ( SQLLoader) WARNING - Failed to execute SQL in file udb06660.sql
[java]
[java] com.ibm.db2.jcc.am.SqlException: DB2 SQL Error: SQLCODE=-614, SQLSTATE=54008, SQLERRMC=PR_DATA_TOKEN_IDX1, DRIVER=4.8.86
[java] at com.ibm.db2.jcc.am.gd.a(gd.java:679)
[java] at com.ibm.db2.jcc.am.gd.a(gd.java:60)
[java] at com.ibm.db2.jcc.am.gd.a(gd.java:127)
[java] at com.ibm.db2.jcc.am.wm.c(wm.java:2510)
[java] at com.ibm.db2.jcc.am.wm.d(wm.java:2498)
[java] at com.ibm.db2.jcc.am.wm.b(wm.java:1918)
[java] at com.ibm.db2.jcc.t4.fb.h(fb.java:221)
[java] at com.ibm.db2.jcc.t4.fb.b(fb.java:47)
[java] at com.ibm.db2.jcc.t4.t.b(t.java:38)
[java] at com.ibm.db2.jcc.t4.ub.h(ub.java:114)
[java] at com.ibm.db2.jcc.am.wm.gb(wm.java:1913)
[java] at com.ibm.db2.jcc.am.wm.a(wm.java:3004)
[java] at com.ibm.db2.jcc.am.wm.e(wm.java:1016)
[java] at com.ibm.db2.jcc.am.wm.execute(wm.java:1000)
[java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:266)
[java]
[java] 2016-06-24 05:28:55,188 ( SQLLoader) WARNING - Statement: CREATE INDEX PRPCUSER.pr_data_token_idx1
[java] ON PRPCUSER.pr_data_token
[java] (
[java] pzClientID asc,
[java] pyUserIdentifier asc,
[java] pyScope asc,
[java] pyGrantType asc
[java] )
[java] Exception in thread "main" com.pega.pegarules.install.SQLLoader$SQLLoaderException:
[java] ********************************************************************************
[java]
[java] Encountered a SQL Exception, clean schema before running again.
[java]
[java] at com.pega.pegarules.install.SQLLoader.fail(SQLLoader.java:359)
[java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:316)
I tried to run the sql what is there in "udb06660.sql" directly in DB2 and got the below error.
pzClientID asc,
pyScope asc,
pyGrantType asc
The index or index extension "PR_DATA_TOKEN_IDX1" cannot be created or altered because the combined length of the specified columns is too long.. SQLCODE=-614, SQLSTATE=54008, DRIVER=3.68.61
