Rulebase setup failed
[exec] pg_restore: processing item 8699 STDSTRINGS STDSTRINGS
[exec] pg_restore: processing item 7 SCHEMA sqlj
[exec] pg_restore: creating SCHEMA sqlj
[exec] pg_restore: [archiver (db)] Error while PROCESSING TOC:
[exec] pg_restore: [archiver (db)] Error from TOC entry 7; 2615 70061055 SCHEMA sqlj postgres
[exec] pg_restore: [archiver (db)] could not execute query: ERROR: schema "sqlj" already exists
[exec] Command was: CREATE SCHEMA sqlj;
[exec] pg_restore: processing item 1658 FUNCTION java_call_handler()
[exec] pg_restore: creating FUNCTION java_call_handler()
[exec] pg_restore: [archiver (db)] Error from TOC entry 1658; 1255 70061056 FUNCTION java_call_handler() postgres
[exec] pg_restore: [archiver (db)] could not execute query: ERROR: could not access file "pljava": No such file or directory
[exec] Command was: CREATE FUNCTION java_call_handler() RETURNS language_handler
[exec] LANGUAGE c
[exec] AS 'pljava', 'java_call_handler';
