Mastercard
Fresh Pega 7.1.9 Install
I have installed fresh pega 7.1.9 on dev environment. when i go to higher environment installation, instead of re-doing the work, can i just simply copy the rules and Data schema?
I believe in higher environments, if we clear few cache tables and few data schema related tables it will work. Can you please confirm? and i can use this as a master copy.
When i installed below are the rule tables and Data schema counts.
| Rule_Table Name | Counts |
| PR_INDEX_REFERENCE | 906427 |
| PR_SYS_APPCACHE_DEP | 184345 |
| PR4_RULE_VW | 148957 |
| PR_ENGINECLASSES | 117927 |
| PR_ASSEMBLEDCLASSES | 94563 |
| PR_INDEX_CSS | 88043 |
| PR4_RULE | 77616 |
| PR4_RULE_SYSGEN | 56842 |
| PR_SYS_APPCACHE_SHORTCUT | 48683 |
| PR_REFERENCE_PAGE | 44563 |
| PR4_RULE_PROPERTY | 28435 |
| PR_SYS_RULE_IMPL | 25444 |
| PR_DATA_MAP_ENTRIES | 22374 |
| PR_SYS_APPCACHE_ENTRY | 21400 |
| PR_SYS_CLASS_ANCESTORS | 17120 |
| PR4_RULE_LIBRARY | 9677 |
| PR_SYS_DECCHG | 9511 |
| PR4_RULE_FILE_BINARY | 9314 |
| PR4_FIELDVALUE | 8495 |
| PR4_RULE_FILE | 6583 |
| PR_CHANGELOG | 5503 |
| PR4_BASE | 4282 |
| PR4_RULE_MESSAGE | 2068 |
| PR4_RULE_RULESET | 977 |
| PR4_RULE_FLOW | 927 |
| PR4_RULE_DECLAREPAGES | 682 |
| PR_SYS_RULESET_INDEX | 630 |
| PR_LINK_USECASE | 469 |
| PR_INDEX_CUSTOMFIELDS | 449 |
| PR_INDEX_RULE_AGENTS | 129 |
| PR4_RULE_SHORTCUT | 125 |
| PR4_RULE_USECASE | 56 |
| PR_SYS_APP_RULESET_INDEX | 42 |
| PR_SYS_APP_HIERARCHY_FLAT | 10 |
| PR_DATA_RULE_APPMETADATA | 3 |
| PR4_RULE_DELEGATIONCONFIG | 3 |
| PR_DATA_ADMIN_PRODUCT | 1 |
| Data Table Name | Counts |
| PR_DATA_ADMIN | 230 |
| PR_DATA_SAMPLE_UIDETAILS | 104 |
| PR_DATA_SAMPLESRPURCHASE | 90 |
| PR_SYS_QUEUE_FTSINDEXER | 37 |
| PR_SYS_WORKINDEXER_QUEUE | 37 |
| PR_DATA_SAMPLESRCUSTOMER | 28 |
| PR_DATA_SAMPLE_SHOPPINGCART | 25 |
| PR_SYS_UPDATESCACHE | 20 |
| PR_DATA | 16 |
| PR_LICENSE_PARAMETERS | 15 |
| PR_DATA_DMS_CUSTOMER | 10 |
| PR_OPERATORS | 9 |
| PR_DATA_SAMPLESRPRODUCT | 6 |
| PR_SYS_STATUSNODES | 5 |
| PI_DATA_CONNECT | 1 |
