Expand/ Collapse text change not behaving properly in Pega 7
Hi All
In Pega 7, we observe that there is a change in behavior of the expand/Collapse tooltip text where the chronology is as below -
Case 1 : Header is collapsed by default
1. Disclose + Header Name
2. Hide + Header Name
Case 2: Header is expanded by default
1. Click to collapse + Header Name
2. HideClick to Collapse + Header Name << This is an issue as it should be Hide Header Name>>
After this, if we click on any of the expanded/collapsed header same concatenation of text "HideClick" or "HideDisclose" is coming and also it is behaving opposite sometimes - the entire series of expand/Collapse is effected.
Please note in Pega 6 we are having a standard default static text "Click to expand/Collapse".
Can you please advise on this issue?
Many Thanks
