Rabo Bank
Menu options are not available under Designer Studio icon in developer portal after PEGA 7 Upgrade
We have upgraded our application from 6.2SP2 to Pega 7.1.8. We are using SCM framework. For post upgrade tasks when we login to developer portal, we are not getting menu options which are normally available under designer studio icon. As part of post upgrade we are using Application Based Validation(ABV) for rulesets.
Tech Mahindra
Hi Nikhil,
Can you please check if you have upgraded SCM framework.
Also please check if SCM is part of your application stack or not.
Rabo Bank
Hi Vamsi,
We have upgraded SCM framework and SCM is a part of our application stack.
Tata Consultancy Services
Hi Nikhil, Did you check the logs after the upgrade was run? Were there any errors encountered in the logs during the upgrade process?
Paypal Inc
Did this happen post framework upgrade ? Prior to upgrade did you override any landing page menu or navigation rule ?
Rabo Bank
@Summet: Yes we did. We didn't find any error in logs. And strange thing is this is happening only with application specific operators. i.e. if we login with administrator navigation is working fine.
Rabo Bank
@sudharsan: This is happening post upgrade of framework. We didn't override any navigation rule prior to upgrade.
Are you able to see the OOTB Pega 7 Menu options or SCM framework Menu Options? Can you double check whether you have customized pyMainMenu navigation rule in your application?
Please let me know if this issue fixed?If so please share the root cause and the fix.
The general root cause for this issue is if you have overriden any of the OOTB provided menu rules from the framework.
