CSSA Practice Exam
Hi team,
In CSSA practice exam, one question about rule resolution is as follows,
- Ruleset1:01-05
- Ruleset2:02-03
- Ruleset3:01-17-50
Rule | Applies To class | Ruleset & Version | Availability |
A | Org-Div-Work | Ruleset1:01-04-02 | Yes |
B | Org-Div-Work-ABC | Ruleset2:01-02-01 | Blocked |
C | Org-Div-Work-ABC | Ruleset3:01-17-99 | Withdrawn |
D | Org-Div-Work | Ruleset2:02-02-01 | Yes |
E | Org-Div-Work-ABC | Ruleset3:01-09-12 | Yes |
Which version of section XYZ does the system attempt to use when processing a case of type ABC?
I have followed all the rule resolution steps, i think at last The " Rule-A" should pick, but the answer is showing as Rule-E,
When i'm doing the rule resolution i have followed few steps for withdrawn rule as below
During the ranking process, the system evaluates any of the candidates that have their
Availability set to ”Withdrawn”. Withdrawn is a special Availability that lets us skip over some
candidates. When a rule is marked as Withdrawn, it is removed from the list of candidates as
well as any additional candidates that match all of the following:
The same ‘AppliesTo’ Class
The same Ruleset Name
The same Ruleset Major version
The same Purpose
The same Qualifiers
This is the definition of how to match a Withdrawn rule. However, during Rule Resolution, the
incompatible Major versions and Purposes have already been discarded in the preceding steps.
At this point, we’re only concerned with the rule being in the same class, in the same RuleSet and
having the same qualifiers.
according to the above steps the "Rule-E" should be remove because, "Rule-C" availability is withdrawn and it satisfy the above conditions.
Can any one please explain me, Why Rule-A is not pricked instead of Rule-E.
Thanks.
