mistake in practice exam CSSA 7.2?
hi,
Question 3
Show More
hi,
Question 3
An application rule lists the following application rulesets, in order:
There are five instances of a section rule named EnterClaimDetails in the rules cache as shown below:
When a user runs the application, which version of EnterClaimDetails is selected during rule resolution, when processing a fraud claim?
- RulesetA:01-05
 - RulesetB:02-03
 - RulesetC:01-17-50
| Applies to class | Ruleset & version | Availability |
| Org-Div-Work | RulesetA : 01-04-02 | Available |
| Org-Div-Work-FraudClaim | RulesetB : 01-02-01 | Blocked |
| Org-Div-Work-FraudClaim | RulesetC : 01-17-99 | Withdrawn |
| Org-Div-Work | RulesetB : 02-02-01 | Available |
| Org-Div-Work-FraudClaim | RulesetC : 01-09-12 | Available |
Org-Div-Work-FraudClaim - RulesetC:01-17-99
Org-Div-Work-FraudClaim - RulesetC:01-09-12
Org-Div-Work - RulesetB:02-02-01
Org-Div-Work - RulesetA:01-04-02
Org-Div-Work-FraudClaim - RulesetB:01-02-01
Question 3 in the Application Design part of the exam, handles about rule resolution. According to the solution the selected rule is Org-Div-Work-FraudClaim - RulesetC:01-09-12. In my opinion this rule should be removed from the cache, because the other rule in RulesetC is withdrawn, shares the same ruleset and the same class.
I think that "Org-Div-Work - RulesetB:02-02-01" and "Org-Div-Work - RulesetA:01-04-02" are equally qualified (the only ones left), and that the resolution would end with a duplicate search. Is this reasoning correct, and thus a mistake in the exam? Thank you.
Thijs
Show Less
