Accenture
Last activity: 24 Nov 2015 4:56 EST
Live UI not working after Upgrade to 7.1.8
Added UI-Kit in ruleset stack. But it is not working in Work User portal
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689962000/6a588e6d-1aff-40ee-a0dc-520a480b2b6c.png?itok=YCZZNgKh)
In order to resolve the issue that you are experiencing a thorough review of all of the factors contributing to the issue is required. Please submit a Service Request (SR) so that one of our Customer Support technicians can work with you on this. You can do so by contacting Pegasystems Global Technical Support through My Support Portal.
The PDN Support Team,
Lu
if the when rule pyEnableUIInspector checking for privilege 'pxUIInspector' returning false then
- the Live UI button will be disabled.
could you please check the associated privileges for work user portal.
Thank you!
Accenture
The required priviledge 'pxUIInspector' is in role SysAdm4 and the role do exist in Access Group. Still it is not working.
However any new pop up window launced have Live UI working.
Cognizant
Hi Rahul,
Is the Live UI is working now?
I am also having the same issue. Can you tell me what have to do?
Accenture
Hi Venkatesh
I still have the issue but LiveUI works fine in Google Chrome; not in IE 11. (Exception- In Pop Up window it works)
Since this is not on my priority list, I have left this to resolve at later point of time. Do share if you get any resolution
Accenture
I have included <pega:include name="pzPegaCompositeGadget_PortalInclude" type="fragment" /> in customized work area, apart from above steps.
Live UI started working.
Accenture
I think Live UI works in Composite portal , not in traditional portal.
You can try launching any of the Pega 7 compiste harness and then check Live UI is working
