AIG
"token recognition error" step hung and stopped
Rule base upgrade steps- most of the steps has worked properly and went fine with "jre7" however it stopped without any exception of message to below step; Challege in analysis was logs didn't had any error or exception;
     [java] 2015-10-04 12:36:35,130 [            tss4l831] [  STANDARD] [                    ] (_Landing_System_Upgrade.Action) INFO    - Flow Validation: 300 instances processed of 1480
     [java] line 1:19 token recognition error at: ''In'
     [java] line 1:29 token recognition error at: '''
     [java] line 1:19 token recognition error at: ''Do'
     [java] line 1:30 token recognition error at: '''
Solution : Instead of JRE7 path, use JDK7 as given in installation/upgrade guide; this has resolved above issue;
