Sensiple Software Solutions Pvt Ltd
Last activity: 26 Aug 2019 7:25 EDT
I am getting an "pyCommit error" when I run my case
I am getting "pyCommit error" when I run my case for past two days. Previously it worked fine. Please suggest me some solution
FR
Can you trace this issue, it will be easiest to DEBUG. Or do you have anything else on your logs maybe.
I have used tracer. It is showing the status as fail. But I dont know how to debug it.
FR
Right,
Can you share the tracer XML for review?
Sure, Please refer the below link
http://s3.pdfconvertonline.com/convert/p3r68-cdx67/mzppx-s7lty.pdf
Hi Leelavathi,
Thanks for posting the query. Please find the below link which will be helpful for the pycommit error.
Since it is failing, you can see some lines with red colour (either withe exception or error). You need to click the line and check exactly what is the error message are you getting in Tracer
Also, check the logs as well to get the complete stack trace
Could you please check if there are any commit in the any activity and if it is present please remove it and then try the use case.
Also could you please try changing the table of the class group and then check if it is working fine or not.
Vikash
I haven't configured any activity.
