Calculate a Property Value
When I added a field to create the "Total PTO" field, it defaults to "Text" and does not allow me to select Number (decimal). I assume because of that, when I select "Calculated (read only)" option, I am not able to do a "Sum of" because it thinks it is a text.
I have tried to delete this field and followed advice from another forum posting to delete the PTO Leave and set up PTO Object. This had other issues related to that approach so I am back to my original issue with PTO Leave.
Please advise on how I can get the Total PTO property to be a Number (decimal) instead of a text.
Thank you,
