Morgan Stanley
Last activity: 10 Oct 2021 8:09 EDT
Dynamic property expression calculation
I have a couple of properties on Clipboard and i would like to do some computations dynamically like below
.First = 10
.Second = 10
Expression: ".First + .Second"
I would like to dynamically calculate the expression value, as we do with expression builder.
Do we have any OOTB function or java api
@Avinash.Haridasu , did you check this https://community.pega.com/knowledgebase/articles/application-development/84/about-declare-expression-rules?
@Avinash.HaridasuDo you mean dynamically means the properties will differ or only values of properties?
Morgan Stanley
@pavan3753 yes Properties will also differ and also the calculation also differs.
Now i have .First + .Second, Later i might pass .First / .Second or .ABC * .XYZ
They are dynamic and i cant use a declare expression @AngelHermira
I'm looking for some function or java api, which can accept the calculation .First + .Second + .Anything as an argument, and return the result.
As we do with the test functionality of expression builder popup.
How are you intending to compose and validate the formula (variables with operations) that will be the parameter to the function? you can pass the formula as a parameter but validating the references and operations might be the bigger cost depending on how you are planning to do that.
Morgan Stanley
@Angel Hermira Yes, You're right.
My operations are very simple, not intending to have more than two or three props.
Not sure if we have any function OOTB or if test in expression builder is exposed to clients.
Sorry, but I still don't understand how the formula will be created. Do you plan to expose the text in a business portal?, do you plan to expose Expression builder if available?, do you plan to create a UI to handle it?
Updated: 24 Sep 2021 11:16 EDT
@Avinash.Haridasu see if the attached approach works using GetPropertyValue function.
1. Capture your property names in two parameters (ex. FirstProp and SecondProp)
2. Get the values of the properties in another two params (ex.FirstPropMap, SecondPropMap) using function i.e. @GetPropertyValue(Param.SecondProp,tools)
3. Based on the mathematic operator captured (Ex. Operand) define the logic
Property names are passed to the parameters FirstProp and SecondProp
@Avinash.Haridasu pyCount and pxResultCount are OOTB properties used for testing instead of creating new properties. Those are not intended for counting in the example
Updated: 24 Sep 2021 13:58 EDT
Morgan Stanley
@kalls4 I think you got me wrong.
I meant to say my properties are very different in data type.
.A + .B + .C and so on or .A * .B etc or .A + 100
The number of properties are different and in our case we used two..
I'm trying to understand if i could leverage the same API used in expression builder test .
Morgan Stanley
I'm still awaiting some suggestions from the forum
Maantic Global IT Solutions
can these expressions be categorized in such a way that based on input value to a decision table/decision tree it can return the expression ".A + .B + .C" OR ".A * .B" OR ".A + 100" ?
