Macquarie Bank
Last activity: 1 Apr 2016 8:41 EDT
Attaching emails via drag and drop
Hi
Is it possible to attach an email from outlook as an attachment using drag and drop via outlook? Or do we need to always save down the email as a .msg file and then upload that as an attachment
NIIT Technologies Limited
I think it's not possible to attach an email from outlook using drag and drop.
You have to save and then attach.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1690552000/ba9eb6d1-3aa8-42b4-8ef7-2a69e5e43188.jpg?itok=vi7tjWvm)
Xebia USA Inc
Areteans Technology
Needs a manual step to save .msg before drag and drop :)
Coned
its possible, which version of Pega you are using??
Macquarie Bank
Hi, we are on 7.1.8. Thanks
PEG
I tried in 7.1.8. I wasn't able to attach the email using drag and drop feature without saving the email to local system.
Can you suggest what are the steps to achieve the same?
Xebia USA Inc
Coned
In 7.1.8, its not working.... its working until 7.1.6. I heard that Pega is not supporting drag and drop from outlook as they are trying to get away from ActiveX controls.
Capgemini
@JaydevDoshi- Could u please share the PRPC version u using?
thanks
Sharad
Coned
from 7.1.8, It seems Pega is trying to get away from Activex controls and drag and drop from outlook is no longer supported.
If you want to use drag and drop from outlook, change your IE compatibility settings to display in compatibility view... you need to test the application thoroughly as it might impact other areas.
Agriculture Victoria
Drag & drop ActiveX control in Pega 7.1.8 has been finalised to be used only for IE 9. So, if you are on any other version of IE (or any other browser), drag & drop ActiveX is not loaded but an HTML5 control is used which does not support drag/drop directly from outlook.
HCLTech
Hi JaydevDoshi,
faced similar issue in Pega 7.1.6 the same has been resolved after importing the HotFix DL-48011, hope this will resolve your issue
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689978000/b4afec62-5ab0-4473-a99a-721caf40b9cc.jpg?itok=CZ-G1th3)
HCL
How to achieve this functionality in pega 7.1.8 (Drag and drop a mail from outlook).
Anyone knows how to activate active x controls in 7.1.8.
Anto
Coned
I think versions lesser than IE11 will display Activex controls. In IE11, you might need to enable compatibility settings to enable drag n drop from outlook. It looks like Pega is trying to get away from ActiveX Controls in the newer versions.
