Stratosphere Technical Consulting
Last activity: 25 Jun 2015 15:09 EDT
Case Steps & Flow references
When we enter a new step it will create a new flow in the appropriate class. For example when we create a Select Medical Benefits step in our case designer for the BenefitsEnrollment step, the corresponding flow rule can be found in application explorer, SAE-HRServices-Work-BenefitsEnrollment under the Process rule category.
Where is this configured, in other words where is the name of the flow rule specified that is called by the step?
Also if a case is saving rules such as flows and flow actions in the wrong class, what could be the cause of this ?
Thanks.
