Wrong flow when testing Run for flow with parallel steps
I am following the SAE1 course. After completing the assignment "Model Processes with the Process Outline" I used the Run option to test the draft flow so far. I noticed that the flow ended after the phase "4. Decision" instead of continuing to "5. Offer". Correct behaviour would have been to prompt for the outcome of the decision in "Asess candidate" as well as to prompt for the missing form of "Background check". After completing both steps the process should proceed to "5 Offer".
To test my assumption I changed said steps to sequential steps temprorarily and then the flow behaved correctly when performing a draft Run.
Kind regards,
Gerard Ohm
CGI The Netherlands
