Workbaskets in CaseManager7
My understanding is that a workbasket is assigned to a workgroup and a workgroup has a default workbasket. A workbasket makes itself available to a set of roles. An operator is assigned to a workgroup and has a set of roles defined in it's access group. My question is if an operator is specifically given a subset of workbaskets to work from, why do all the workbaskets in the work group show up in the case manager 7?
Also, how would I display/list only the work in a workbasket that the operator can actually work on?
What version of Pega 7 are you using? Check About Pega7.
Roberta
