CVS
Last activity: 18 Mar 2015 13:17 EDT
Data Propogation VS SOR Approach
I have a parent case and I capture the client information in the parent case. Now I will have a bunch of child cases which might need to use that client information which is present in the parent case. Now I have three approaches.
- Propagate the client data from parent to child on instantiation.
- Directly refer to the parent data from the child.
- Use an SOR approach store the client data in a separate table after capturing the client data at the parent. Propagate the SOR key to the children, and use that key to refer/modify that client information.
I feel third option is best, but there are two types of clients one with Class/Dept as key and another one as Class/Dept/Div as the key, now how do I form the key as Div will be blank for the first type of client. In that case I should just use a Serial number as the key, and manually making sure this serial number is unique when we add each client.
Pradeep
