JPMC
Last activity: 25 Jan 2016 6:46 EST
Data propogation from sub case to parent case not working for page properties
Hi ,
In my application i need to track page property changes on subcase and calculate values on parent case. We have used OOTB calculations tab of the Case type rule. But the values are not getting propagated from sub case to cover case.
Pega version : 7.1.7
Core PRPC. No frameworks being used.
Likes (1)
Sarath babu Vijaykumar -
Virtusa
HI Sri,
There is no methods for auto prorogation of data from covered to the cover.
If needed, please use it manually.
JPMC
There is calculations tab on a case type rule. that functionality is not working for aggregate properties
thanks
Sriharsha
Virtusa
Hi Sri,
Could you please share the configurations.
Please explain what you meant by aggregate property.
I have tried the same, and is working fine for me.
Thanks.
JPMC
There is a page property, inside which there is a single value property.
Page.SingValueProperty
If any changes on this property happens on sub case then
page2.singlevalueproperty values needs to be incremented .
Virtusa
Whether page2.singlevalueproperty is in parent case???
JPMC
yes its a parent case property
Virtusa
Hi Sri,
Could you send the screen shot of the Calculations Window of the case type.
Hope the calculations is used to get values from the different covered Work types to the parent case.
Please let me know what you meant by increment?
Thanks.
JPMC
Yes it is from covered work types i am getting values onto parent case.
Increment here i mean is sum of the individual properties.
Sorry i cant give the screen shot - Confidential
Virtusa
That's fine...
Could you please verify whether the declare trigger activity is created for the covered case types.
Thanks.
JPMC
Yes they are created . From the subcases the declare trigger activity is getting invoked and all the processing is being done but values are not getting populated on the parent case
Virtusa
I have replicated the same scenario in my local environment, with multiple sub-cases.
Its working fine.
Please share some other details to further investigate on this.
