Last activity: 23 Jan 2018 5:55 EST
Using Pega File Manager
About this document
06February2017: From the PDN Support page, https://pdn.pega.com/search/product-support, scroll to the Resources list to see the link to the PDF, Using Pega File Manager, https://pdn.pega.com/documents/using-pega-file-manager. (See the attached screenshot.)
This document is intended to help Pega customers who use the new Pega File Manager that will replace the Pega File Transfer Appliance, effective January 31, 2017.
As a Pega customer, you will typically use Pega File Manager to send and receive large files related to your Support Requests (SRs) with strong security protection.
If you see references to Cerberus in the user interface or in the example screens shown in this document, do not be confused. Cerberus is the brand name of the FTP server that we use to host the Pega File Manager.
Most Pega File Manager features and user interface controls are intuitive; therefore, not every feature is described in this document.
Receiving files
You can receive files from someone using the File Manager in several ways, depending on the sender’s choice of File Manager Share mode:
- Folder
- By link
- By email
- File
- By link
- By email
Receiving a folder through an automatically generated email
Your notification looks like this example.
Receiving a folder through a direct link
You can access the folder with the files you need here: https://sftpcam.pega.com/public/folder/K_3yxstYDkSckFEgdYwtXg/SR-B9873
Receiving a file through an automatically generated email
Receiving a file through a direct link
You can download the file you need here: https://sftpcam.pega.com/public/file/2V_OywqnMkavzdDJ8RtK2g/DL-63926.zip
Sending files
To send files, follow these steps:
- Check whether the file can be attached directly to the SR through My Support Portal.
This is the preferred method for attaching files.
If the file is large, compress it as a .zip file or 7z archive before attaching. - If the file is still too large to attach to the SR even after compression, contact the Pega customer support engineer working on your case.
The GCS engineer will provide a link to a folder where you can upload the file and a password to access the folder. - Click the folder link provided and enter the password.
- After you have opened the folder, click Add Files and select your file.
- Finally, click Upload Files.
A progress bar will appear to show the status of the upload.
- To preview an uploaded file, click Preview.
File Manager displays a white screen (Preview window) with the file link at the bottom, similar to a file download.
- To download a selected file, click Download.
File Manager Download works like any browser download.
***Updated by moderator: Lochan to add Group Tag: Blog***
