Upgrade in Production when having Oracle Synonyms
The application is having the PegaRULES schema in Oracle and has synonyms for each of the Pega DB object. The upgrade approach performed in the sand-box / Dev is in-place upgrade first and later split the schema.
In the Production should we repeat the process of performing in-place upgrade and then a split?
Or, if we do a lift-shift then will dataOnly upgrade be successful considering it having synonyms?
