Production Upgrade Approach Challenge
Issue Description:
We have upgraded our environment from Pega 62sp2 to Pega7.2 . We have upgraded from single schema to split schema in our lower environments.
We are planning to perform the upgrade on our Production environment.
We have current schema of Pega62sp2 lets say (rule+data) "X".
We will be planning to push the upgrade onto new schemas DataSchema "Y" and rule schema "Z".
Post upgrade onto production the environment will be tested for stability for a week. During that week the users will continue to use Pega62sp2 (schema "X").
Once we get a sign off on Upgraded environment we will require to move the delta transaction data which was created by user on previous week from schema "X" onto the new split schema "Y" and "Z".
Could you please suggest what's the best way to move the delta from single schema onto split schema ?
Would you recommmend anyother approach for PROD upgrade?
Database: Oracle 11g
Webserver: Apache
Appserver: Tomcat
Server OS: Linux
***Updated by Moderator: Marissa to move to Pega 7 Upgrade Center from Product Support Community***
