Upgrade Failed with Network Adapter could not establish connection error
During the upgrade of migrated rules, the ugprade failed with the above error. The complete stack trace is given below.
[java] Using sun.misc.Perf high-resolution timer for elapsed timings
[java] Using Java 5 Management beans for thread CPU timings.
[java] Using Java 5 Management beans for process CPU timings: 3840000000
[java] 2015-11-20 12:33:34,043 [ main] [ ] [ ] (.access.PageDatabaseMapperImpl) INFO - DeflateStreams is turned ON.
[java] 2015-11-20 12:33:34,105 [ main] [ ] [ ] (pboard.StorageStreamCommonImpl) INFO - engineCodeVersion: 07-10-17
[java] Unable to locate KeyringImpl keyring after trying:
[java] <properties>
[java] root-pegarules.keyring
[java] WHE-304-pegarules.keyring
[java] 2015-11-20 12:33:35,852 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) WARN - The database pegadata is only defined in the bootstrap configuration; create a Data-Admin-DB-Name definition
[java] pegarules.keyring
[java] Nov 20, 2015 12:34:35 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] SEVERE: Problem during method invocation (main)
[java] com.pega.pegarules.pub.PRException: A problem occurred.
[java] From: (unknown)
[java] at com.pega.pegarules.deploy.internal.util.ImportImpl.main(ImportImpl.java:398)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[java] at java.lang.reflect.Method.invoke(Method.java:606)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java] Caused by: com.pega.pegarules.pub.PRRuntimeException: Error determining the mode of PRPC install from database.
[java] at com.pega.pegarules.data.internal.PRDataProviderImpl.isMultiTenantEnvironment(PRDataProviderImpl.java:1135)
[java] at com.pega.pegarules.deploy.internal.archive.ParUtilsImpl.setStageDirectory(ParUtilsImpl.java:219)
[java] at com.pega.pegarules.deploy.internal.archive.ParUtilsImpl.copyFileToVfsRoot(ParUtilsImpl.java:315)
[java] at com.pega.pegarules.deploy.internal.util.ImportImpl.main(ImportImpl.java:261)
[java] ... 9 more
[java] Caused by: com.pega.pegarules.pub.database.ConnectionException: Database-General Problem encountered when getting connection for database pegarules 17002 08006 IO Error: The Network Adapter could not establish the connection
[java] Caused by SQL Problems.
[java] Problem #1, SQLState 08006, Error code 17002: java.sql.SQLRecoverableException: IO Error: The Network Adapter could not establish the connection
[java] at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:256)
[java] at com.pega.pegarules.data.internal.access.ConnectionManagerImpl.getConnectionFromDatabaseName(ConnectionManagerImpl.java:856)
[java] at com.pega.pegarules.data.internal.access.ConnectionManagerImpl.getConnection(ConnectionManagerImpl.java:1187)
[java] at com.pega.pegarules.data.internal.access.ConnectionManagerImpl.getConnection(ConnectionManagerImpl.java:1129)
[java] at com.pega.pegarules.data.internal.access.ConnectionManagerImpl.getConnection(ConnectionManagerImpl.java:343)
[java] at com.pega.pegarules.data.internal.PRDataProviderImpl.isMultiTenantEnvironment(PRDataProviderImpl.java:1125)
[java] ... 12 more
