HCL TECHNOLOGIES
Last activity: 28 Apr 2015 6:46 EDT
Unable to start prpc
when i am started prpc i got the fallowing on command prompt.unable to start process commander.got http 404 error.
] ( etier.impl.EngineStartup) INFO - OS: Windows 7, version: 6.1
2015-04-28 06:28:01,570 [ocalhost-startStop-1] [ ] [
] ( etier.impl.EngineStartup) INFO - Architecture: amd64
] ( etier.impl.EngineStartup) INFO - PegaRULES Enterprise Tier 6.3 (SP1
] ( etier.impl.EngineStartup) INFO - coreAssemblyCached_63SP1_38: 2012-
10-27 08.33 EDT
] ( etier.impl.EngineStartup) INFO - Deployed in web tier only
] ( etier.impl.EngineStartup) INFO - Servlet con
tainer: Tomcat
] ( etier.impl.EngineStartup) INFO - Web
server: Apache Tomcat/7.0.28
] ( etier.impl.EngineStartup) INFO - Web server envir
onment: Tomcat
] ( etier.impl.EngineStartup) INFO - Web-tier default Engine bea
n name: EngineBMT
] ( etier.impl.EngineStartup) INFO - Web to Enterprise tier delegat
e type: pojo
] ( etier.impl.EngineStartup) INFO - Now starting the PegaRULES Engine.
2015-04-28 06:28:01,680 [ocalhost-startStop-1] [ ] [
] (l.access.ConnectionManagerImpl) INFO - Using Thread Local Saved Connectio
ns
Unable to locate KeyringImpl keyring after trying:
<properties>
SATYA-pegarules.keyring
SATYA-PC-pegarules.keyring
pegarules.keyring
2015-04-28 06:28:01,840 [ocalhost-startStop-1] [ ] [
] (l.access.ConnectionManagerImpl) INFO - Base database information:
] (l.access.ConnectionManagerImpl) INFO - Defined by: JNDI name
] (l.access.ConnectionManagerImpl) INFO - Data source name: java:com
p/env/jdbc/PegaRULES
] (l.access.ConnectionManagerImpl) INFO - Minimum connection count:
0
] (l.access.ConnectionManagerImpl) INFO - Maximum connection count:
unlimited
] (l.access.ConnectionManagerImpl) INFO - Failover database: none
2015-04-28 06:28:02,320 [ocalhost-startStop-1] [ ] [
] ( external.timers.CpuTimer) INFO - CPU timers set to TOTALSONLY. Use
prconfig setting 'initialization/CpuTimerLevel' with one of [FULL, TOTALSONLY, N
ONE] to modify.
] (.timers.EnvironmentDiagnostics) INFO - Using Java 1.5 Thread.getAllStackT
races() for thread dumps
Using sun.misc.Perf high-resolution timer for elapsed timings
Using Java 5 Management beans for thread CPU timings
Using Sun Java 5 Management bean for process cpu timings
2015-04-28 06:28:02,780 [ocalhost-startStop-1] [ ] [
] (.access.PageDatabaseMapperImpl) INFO - DeflateStreams is turned ON.
Using Java 5 BigDecimal implementation
2015-04-28 06:28:03,580 [ SATYA-PC] [ ] [
] (rnal.mgmt.InitialConfiguration) INFO - Generated source : file://runtime:
/PRGenJava/
] (rnal.mgmt.InitialConfiguration) INFO - Generated classes: file://runtime:
/PRGenClasses/
2015-04-28 06:28:03,660 [ SATYA-PC] [ ] [
] (rnal.mgmt.InitialConfiguration) INFO - Web-tier real root path: C:
\PRPCPersonalEdition\tomcat\webapps\prweb
] (rnal.mgmt.InitialConfiguration) INFO - Web-tier temporary path: C:
\PRPCPersonalEdition\tomcat\work\Catalina\localhost\prweb
] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES real root path: C:
] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective root path: fi
le://default:/
] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective temp path: C:
\PRPCPersonalEdition\temp
] (rnal.mgmt.InitialConfiguration) INFO - Using genSourcePath: fi
le://runtime:/PRGenJava/
] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (database): pe
gajdbc://1951027809:1/
] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (files): fi
le://runtime:/PRGenClasses/
] (rnal.mgmt.InitialConfiguration) INFO - Using external classes in: <n
ot using external classes>
] (rnal.mgmt.InitialConfiguration) INFO - Using external jars in: <n
ot using external jars>
2015-04-28 06:28:03,990 [ SATYA-PC] [ ] [
] (rnal.mgmt.InitialConfiguration) INFO - Servlet classes: C:\PRPCPersonalEd
ition\tomcat\lib\servlet-api.jar
] (rnal.mgmt.InitialConfiguration) INFO - JSP classes: C:\PRPCPersonalEd
ition\tomcat\lib\jsp-api.jar
] (rnal.mgmt.InitialConfiguration) INFO - EJB classes: (none)
] (rnal.mgmt.InitialConfiguration) INFO - JMS classes: (none)
2015-04-28 06:28:04,460 [ SATYA-PC] [ ] [
] (rnal.access.CacheContainerImpl) INFO - Using the Dynamic Cache Probation
Policy - cache after 2 accesses AND with a blob increment of 102400.
2015-04-28 06:28:05,870 [ SATYA-PC] [ ] [
] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warnin
g threshold: 50M
] ( internal.access.DatabaseImpl) INFO - Database product: PostgreSQL
] ( internal.access.DatabaseImpl) INFO - Database version: 9.1.6
] ( internal.access.DatabaseImpl) INFO - Driver: PostgreSQL Native Driver
] ( internal.access.DatabaseImpl) INFO - Driver version: PostgreSQL 9.2deve
l JDBC4 (build 1000)
2015-04-28 06:28:05,990 [ SATYA-PC] [ ] [
] (ternal.dictionary.ClassMapImpl) INFO - Reading the class group definition
s
2015-04-28 06:28:06,090 [ SATYA-PC] [ ] [
] (ternal.dictionary.ClassMapImpl) INFO - Read 9 class group definitions
] (ternal.dictionary.ClassMapImpl) INFO - Reading the class definitions
2015-04-28 06:28:11,180 [ SATYA-PC] [ ] [
] (ternal.dictionary.ClassMapImpl) INFO - Read 2963 class definitions
2015-04-28 06:28:17,750 [ SATYA-PC] [ STANDARD] [
] (al.access.InstanceExistsFilter) INFO - Scanning instance ids
2015-04-28 06:28:21,370 [ SATYA-PC] [ STANDARD] [
] (al.access.InstanceExistsFilter) INFO - Added 38893 entries to the instanc
e exists filter in 3.570000 seconds with a false positive rate of 0.0010
2015-04-28 06:28:21,380 [ SATYA-PC] [ STANDARD] [
] (.DeclarativePageDefinitionImpl) INFO - Starting declarative pages pre-loa
d...
2015-04-28 06:28:25,710 [ SATYA-PC] [ STANDARD] [
] (.DeclarativePageDefinitionImpl) INFO - Preloaded 30 declare pages definit
ions in 4330 ms
2015-04-28 06:28:26,010 [ SATYA-PC] [ STANDARD] [
] ( internal.mgmt.PRNodeImpl) INFO - Node Identification: "SATYA-PC prp
cpe 2015-04-28 00:58:04.700 GMT"; Node Id: efa3cb8570c3b602bc65bb56be11a4dc
2015-04-28 06:28:26,110 [ SATYA-PC] [ STANDARD] [
] ( internal.mgmt.PRNodeImpl) INFO - Library version used for database
storage: 2011642557
2015-04-28 06:28:26,320 [ SATYA-PC] [ STANDARD] [
] (nal.library.LibraryUtilityBase) INFO - Using LibraryUtility implementatio
n class: com.pega.pegarules.generation.internal.library.LibraryFunctionUtilityIm
pl
2015-04-28 06:28:28,492 [ SATYA-PC] [ STANDARD] [
] ( internal.mgmt.PRNodeImpl) INFO - Rule-Utility-Library preparation n
ot performed.
2015-04-28 06:28:29,792 [ SATYA-PC] [ STANDARD] [
] (dictionary.ConclusionCacheImpl) INFO - Starting conclusion pre-load...
2015-04-28 06:29:01,836 [ SATYA-PC] [ STANDARD] [
] (dictionary.ConclusionCacheImpl) INFO - Pre-Loaded 47573 conclusions
] (bi.DeclarativeCacheManagerImpl) INFO - Starting global declarative cache
pre-load...
2015-04-28 06:29:36,006 [ SATYA-PC] [ STANDARD] [
] (bi.DeclarativeCacheManagerImpl) INFO - Loaded 2746 global declarative cac
he instances
2015-04-28 06:29:36,946 [ SATYA-PC] [ STANDARD] [
] (c.DependentRuleSetListPoolImpl) INFO - Loaded 640 ruleset dependencies
] (pcentric.RACacheAppCentricImpl) INFO - Start AppCentric reloadCache proce
ssing for node efa3cb8570c3b602bc65bb56be11a4dc. Maximum age in hours for Usage
data is 96. Maximum rows to load is 14400
2015-04-28 06:29:37,016 [ SATYA-PC] [ STANDARD] [
] (pcentric.RACacheAppCentricImpl) INFO - End of reload processing, loaded 0
rows, elapsed time is 70 milliseconds.
2015-04-28 06:29:37,026 [ SATYA-PC] [ STANDARD] [
] (pcentric.RACacheAppCentricImpl) INFO - reload added 0 assembledClasses 0
shortcuts.
2015-04-28 06:29:40,546 [ SATYA-PC] [ STANDARD] [
] ( internal.async.Agent) INFO - Passivation will be done on a per-
page basis.
2015-04-28 06:29:41,186 [ SATYA-PC] [ STANDARD] [
] (ternal.async.PassivationDaemon) INFO - PegaRULES Passivation Daemon initi
alized in web-tier.
2015-04-28 06:29:41,236 [ SATYA-PC] [ STANDARD] [
] (al.async.AsyncServicesExecutor) INFO - PegaRULES Async service executor (
thread pool) initialized in web-tier.
2015-04-28 06:29:41,355 [ SATYA-PC] [ STANDARD] [
] (base.PassivationStorageManager) INFO - Passivation data will be written t
o file.
2015-04-28 06:29:41,405 [ SATYA-PC] [ STANDARD] [
] ( etier.impl.EngineStartup) INFO - PegaRULES engine successfully star
ted. Server: SATYA-PC System: prpcpe Description: efa3cb8570c3b602bc65bb56be11a4
dc URL: http://SATYA-PC:8080/prweb/PRSOAPServlet
2015-04-28 06:29:41,551 [ SATYA-PC] [ STANDARD] [
] (ervlet.WebAppLifeCycleListener) INFO - MBean registered via WebAppLifeCyc
le: efa3cb8570c3b602bc65bb56be11a4dc
Located App Server independent MBean security configuration: pegajdbc://19510278
09:0/prresources.jar!//prmbeans.properties
2015-04-28 06:29:41,608 [ SATYA-PC] [ STANDARD] [
] ( priv.management.MBeanSecurity) INFO - The following MBean security confi
guration has been applied:
2015-04-28 06:29:41,623 [ SATYA-PC] [ STANDARD] [
] ( priv.management.MBeanSecurity) INFO - deny.RequestorManagement.Clipboa
rd=true
] ( priv.management.MBeanSecurity) INFO - deny.RequestorManagement.Request
orDetails=true
] ( priv.management.MBeanSecurity) INFO - deny.DatabaseManagement.Database
ConnectionDetails=true
2015-04-28 06:29:42,178 [ SATYA-PC] [ STANDARD] [
] (riv.management.MBeanManagement) INFO - MBean Management (Web) initialized
for DefaultDomain
2015-04-28 06:29:42,260 [ SATYA-PC] [ STANDARD] [
] (ervlet.WebAppLifeCycleListener) INFO - Web Tier initialization is complet
e.
28 Apr, 2015 6:29:42 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory C:\PRPCPersonalEdition\tomcat\webapps\
docs
examples
host-manager
manager
ROOT
28 Apr, 2015 6:29:42 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-apr-8080"]
INFO: Starting ProtocolHandler ["ajp-apr-9009"]
28 Apr, 2015 6:29:42 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 118965 ms
2015-04-28 06:30:52,354 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 06:30:52 I
ST 2015 Total memory: 966,066,176 Free memory: 685,503,368 Requestor Count: 7 Sh
ared Pages memory usage: 0%
2015-04-28 06:31:04,563 [ PegaRULES-Batch-2] [ STANDARD] [ PegaRULES:06.0
3] ( internal.cache.RAPurge) INFO - skipping purge because HasPurgeHap
penedSinceStartup == false
2015-04-28 06:31:04,969 [ PegaRULES-Batch-1] [ STANDARD] [ PegaRULES:06.0
3] (l.access.RuleCandidateIterator) INFO - Single candidate rule resolution o
ptimization is enabled
2015-04-28 06:40:56,376 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 06:40:56 I
ST 2015 Total memory: 976,420,864 Free memory: 709,067,384 Requestor Count: 8 Sh
2015-04-28 06:50:56,647 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 06:50:56 I
ST 2015 Total memory: 972,095,488 Free memory: 697,841,104 Requestor Count: 8 Sh
2015-04-28 07:00:57,518 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 07:00:57 I
ST 2015 Total memory: 984,612,864 Free memory: 715,850,704 Requestor Count: 8 Sh
2015-04-28 07:10:57,941 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 07:10:57 I
ST 2015 Total memory: 980,484,096 Free memory: 737,585,048 Requestor Count: 8 Sh
2015-04-28 07:20:58,354 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 07:20:58 I
ST 2015 Total memory: 993,198,080 Free memory: 779,937,104 Requestor Count: 8 Sh
2015-04-28 07:30:58,730 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 07:30:58 I
ST 2015 Total memory: 993,198,080 Free memory: 625,470,976 Requestor Count: 8 Sh
2015-04-28 07:40:58,939 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 07:40:58 I
ST 2015 Total memory: 988,938,240 Free memory: 664,717,752 Requestor Count: 8 Sh
2015-04-28 07:50:59,168 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 07:50:59 I
ST 2015 Total memory: 1,001,717,760 Free memory: 717,996,912 Requestor Count: 8
Shared Pages memory usage: 0%
2015-04-28 08:00:59,411 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 08:00:59 I
ST 2015 Total memory: 997,523,456 Free memory: 773,774,680 Requestor Count: 8 Sh
2015-04-28 08:10:59,833 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 08:10:59 I
ST 2015 Total memory: 997,523,456 Free memory: 628,200,808 Requestor Count: 8 Sh
2015-04-28 08:21:00,003 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 08:21:00 I
ST 2015 Total memory: 1,009,844,224 Free memory: 704,679,120 Requestor Count: 8
2015-04-28 08:31:00,171 [egaRULES-MasterAgent] [ STANDARD] [
] ( internal.async.Agent) INFO - System date: Tue Apr 28 08:31:00 I
ST 2015 Total memory: 1,005,912,064 Free memory: 777,117,488 Requestor Count: 8
